262 rebuild
2:11 AM
.... for sanding the BASE .... the BASE ....
..... it's just too damned early in the week to be awake ...
I figured thats what you were saying and brilliant idea. But if you can cut round glass from home you are truly badass
But I DO remember a builder video (Tree Monkey) where they used a mandrel the size of the cylinder with self-stick sandpaper to cut the squish band ...
I seen that too.
paragonbuilder
3:11 AM
Norwich, CT
I saw the video as well, took it off and on a bunch of times till he got it just right, very cool indeed, shame you would need so many mandrels though.
If you do a lot of the same saws, make a mandrel. Or do this
PA Dan
3:11 AM
White Oak PA
I seen that too.
I wish I knew someone that cut round glass. After testing the compression on my 262 the other night I stepped on the guage and broke the glass![emoji22] [emoji36]
Johnmn
2:11 AM
Minnesota
This cylinder had bad transfer, I was finishing cleaning that up and the plating peeled a little below the exhaust port. Do you think it's okay to run it? IMG_20170407_115007151.jpg
3:11 AM
This cylinder had bad transfer, I was finishing cleaning that up and the plating peeled a little below the exhaust port. Do you think it's okay to run it? View attachment 64599
I'd use it too. What did you wind up doing to the jug?
What's the squish you arrived at?
I'd get a cylinder brake hone and hone the jug with some oil and the hone. Then wipe clean and do again with scotchbrite.
I've found that those rough sanding lines in the plating will tear up a piston skirt rather quickly.
Sty57
2:11 AM
Land of Cheese & Beer
What grit stones are you using Al?
Johnmn
2:11 AM
Minnesota
Haven't done anything yet, parts should be arriving this week. I will degree the cylinder this week and post what I find and I'll go from there
