Ketchup
Epoxy member
- 8:29 AM
- Mar 12, 2018
- Colorado
I haven’t run one without the stuffer. Just looking at it, I think it would increase case volume a lot and create a bad shape to the transfer tunnel (big dead space behind the upper).
There’s definitely room to experiment there though. That transfer is very constricted and it’s a primary. I could see widening the tunnel slightly by thinning the stuffer, or removing it and pouring epoxy.
The transfers on this saw are confusing. Each one has its own entry and exit dynamics. I’ve poured a lot of water through them trying to visualize the scavenge pattern, but it’s only a crude indication of what they do in a running engine. They seem over complicated to me.
I haven’t done a 2511t in a few months. When that comes back around the first thing I will do is measure the relationship of the piston at BDC to the flange walls at the transfers. That is the major constriction point. How much of that flange you take away probably has the biggest effect on transfer efficiency.
