- 11:16 PM
- Nov 24, 2023
- Northern Idaho, Ehh
Well, I ordered a carb kit for my 2100s HS136. I was taking my carb apart to give it a good clean as it has some crusty build up. I was pulling off the choke shutter arm and a piece shot out, hit my hand once, the work bench once and disappeared into the void of my workshop (much like e-clips and piston circlips). Ends up it was the choke friction ball that was spring loaded. I swept up best that I could and did not find it.
Does anyone know what size it is? Can you get a bearing or a BB small enough to replace it? It is #5 on the diagram below. The service kit has just about everything but the friction ball (whoever loses those??).
