- 6:07 AM
- Nov 24, 2023
- Northern Idaho, Ehh
Both. I had to raise the exhaust a lot.Did you widen or raise the exhaust?
Did you check to make sure , ur diaphragms and gaskets are in correct order , just saying ,I'm quite befuddled with mine .I did a complete rebuild on the carb including the passages below the welch plugs .I've never had to do that before on any carb .It will fire on a squirt of fuel but die out so it's a fuel delivery problem .It might be a bad seal .Which would explain it .if so .Back to the shed again .
I hate it when gaskets shift when putting things back together.It's probably an intake gasket blocking the impulse channel.
Good thing you aren't a surgeonI left a bit of rag I had been using as a block off in the intake after reassembling an 044 once. A little embarrassing when I finally figured it out.
Impulse was my first thought. You ever seen the impulse blocked in the case or carb body?It's probably an intake gasket blocking the impulse channel.
I soaked mine in Berryman's overnight and it got better but nowhere near fixed. It's getting an ultrasonic bath next. If that doesn't work it's getting a bullet.I don't think the gasket shifted .I have no idea why this thing worked good about this time last summer .However prior to "sawfest " it refused to start .I wanted to run it in the 100 cc class ..As it worked out on a fresh rebuild of the Partner P-100's I used one but again it was only at 140 PSI and didn't do well .That saw has slowly improved in the last year and if the 2100 won't work I'll use it again .The other Husky,281 decided it didn't want to run but I've got the modified 038 Stihl Mag that will out gun it anyway in the 82 cc class . .For reasons unknown I'm beginning to believe Husqvarna is mad at me .
One of the dumbest things I've done in the carburetor category was install a diaphram and gasket on the metering side of the carb, then bolt on the plate that also had a gasket and diaphram on it. Yes, two of each. It actually ran, sort of.Did you check to make sure , ur diaphragms and gaskets are in correct order , just saying ,
That's pretty, nice job!!Alright, port work is done, so one last look before the jug goes back on with some Dirko.
Thanks! I think it will run halfway decent.That's pretty, nice job!!
