- 6:07 AM
- Jun 7, 2023
- Norcal
Serious question. Is high on the clutch side the optimal exit location or are you going to the existing hole as opposed to blocking it off or adding a 2nd exit elsewhere?Did a little work on the muffler this morning. There was a ring of steel above the exhaust port and a perforated baffle under the port. I went in with a double cut burr and cut out both pieces. Now the port opens up to a wide open can. I’m in the process of fitting a deflector high on the clutch side with a second outlet.View attachment 431529View attachment 431530
