- 1:27 AM
- Jan 17, 2016
- cape cod ma.
You’ got me beat, I’ve only got 3 welders and a plasma cutter ........ all blueMiller is my choice. Have 6 Miller welders at the moment.
You tease...
Awesome, I saw your pm first so I replied to it, thanks Mr. Jack.Mr Huskboy, the Husqvarna 555 and 562 does have 3/8 rim sprocket on the drum. I am not sure if it will on a 346 or Jonsered 2153. I do have a 562 and a 346. I do have the clutch tool to remove the clutch to disassemble the 562, then to check on a 346.
Would you like me to try it for you. I do have both, a 562 and 346. I never knew the rim sprocket from a 562 will fit a 346 drum. Let me know......
Jack
Anymore, I just knock the fuzz off the bottom with a straight edge after a plasma cut ......... you get good at either after a whileI had a Snap On Plasma once. I got rid of it. In most cases I can out cut most folks
who use Plasma cutters with a torch. Not in speed but in quality of a cut.
Can’t just use one of mine Mason ?
Yup.all that is needed is a small spline 3/8 rim to be able to do that. Works on any 2253/550/346/2153. I can bring a few if anyone needs them.
