X 66 stang347 X
- 12:45 PM
- Sep 23, 2016
- Georgia
Just go stage 3. Anyone else runnin nos and a pipe? Might inject it this way or through the reed block.
Just need to find an adapter.
Its my chinese saw dan, and ill cry if i want to.Just build your saws for crying out loud... this is not rocket science, it's a Chinese Saw...
[emoji41]
So just to be clear @Mastermind , we have to use the wrist pin bearing included with the kit?
In all classes.
The wrist pin bearing can be from any manufacturer.
In all but class three.
The wrist pin must be an aftermarket part.....and should be original to the top end kit that is used.
Yep. But only because that's all I had. It's getting replaced with oem when it comes back apart for porting. I don't see where changing out a known source of catastrophic failure, yet doesn't add to performance, should be a big deal.
Ya mean like this....Yep. But only because that's all I had. It's getting replaced with oem when it comes back apart for porting. I don't see where changing out a known source of catastrophic failure, yet doesn't add to performance, should be a big deal.
to heck with an air filter... intake atomizer FTW, no pipe thoughJust go stage 3. Anyone else runnin nos and a pipe? Might inject it this way or through the reed block.![]()
Magnum PI on the super good ones!
Mostly I would say no disqualification unless you spank everyone easily. But the original idea of class 1 was as close the out of the box as most people would get. Now maybe if you prove that you flattened it without a lathe or mandrel/cutter, something like sticky sandpaper on the piston.My white box (farmertek?) cylinder has minimal squish without the gasket, also a bit of 'reverse squish', .017" by the cylinder wall and .013" in towards the combustion chamber.
If someone were to fix/flatten the defect/hump on the squish band would that disqualify it for class 1?
The complications begin, lol...
