I will before I change anything.Did you check stock timing numbers yet?
Exactly what I was thinking.Very bad ass
No I didn't. I can't pull it off so it should be tight enough. I'm planning on using some motoseal grey to assure a failure proof bond when I reassemble it after porting.Jim, did you put a groove on the intake neck for the intake boot?
Yeah it's in a pretty good place as it is. For starters I'm opening up the inside of the intake flange to match the boot. That may be all I need to do. But then I think "why go tame on the cylinder if I'm going so balls out on the intake", so this thing should get pretty race like.I think it will be a beast after some grinding
If the cylinder hasn't been lowered then timing will be whatever it was on the 394 chassis which is good numbers
Not quite sure if this is a compliment or ..... NotGee Whiz! Andreas Stihl is rolling in his grave but Erik Dahlbergh is gettin a chub...
Building street stocks twenty years ago in Illinois, a 9" Ford rear end was as much as anyone would try to get by with...that and some skinned panels, truck spring on the right front and grinding three inch of tread off 12" hoosiers to make them look like 9" tires. I remember these one boys from Brownstown who had the lincoln rear end, skinned panels all that, but in their '76 Camaro they also had a 360 with a four barrel and a 727 Chrysler tranny. Dunno what they did to it but it was fast. Everybody knew what they were up to and that it was probably a grenade. Hey man grenades are people too.....
