064 Build
K Mueller
7:05 PM
Alaska, USA
Oil line actually went in relatively easy. Having the line already on the barb before installing the pump is the way to go. I didn’t have the water hot enough, so just used a little help from a heat gun.
Pushed the outlet end of the oil line into the hole cut in the bar pad. Once that was in place I just held the pump and bent the oil line into the recessed portion in the case. At the same time, I slipped the pump over the crankshaft and into place. Secured it and tapped in the brass bushing
Didn’t even need the pliers I fabricated and only took a couple minutes.
539FF623-D41F-4C28-A487-74A35814D5D5.jpeg 6EAD7F44-00DE-4121-9EA4-9A3369C3F21F.jpeg B23912CD-679E-496C-9656-F8470A94624C.jpeg
K Mueller
7:05 PM
Alaska, USA
Waiting on a few more components so it’s going sit as is for a little while. Need a flywheel and a couple other smalls. Also going to order some new plastics that are the lighter shade of orange.
NOS early HD setup
Couldn’t help myself and had to bolt it all up just to see how it looks.
GoBigBlue1984
Bluegrass Fart Knocker...
11:05 PM
Kentucky
Very nice as usual Kyle.
I will add that I’ve used nuts inside the muffler on over 2 dozens 1122’s. I’ve never heard of one coming loose yet. Though a little insurance (weld) certainly can’t hurt.
Edwad
10:05 PM
Indiana
