064/056 mag11 build
srcarr52
4:29 AM
Iowa City
I used a 395 piston in my pipe saw. The weight of it slowed the saw down compared to the OEM piston. I didn't realize how much till I went back to the OEM top end.
You can safely take 10g off a meteor 395 piston. Takes it from 117g to 107g, stock 2100 piston is 112g. I haven't weighed a 066 piston lately and I don't have it in my notes.
3:29 AM
I have used them in the 2100, and the BB 066, and did take a bunch of weight off. But in the pipe saw I lightened the OE piston too. So......
jmssaws
Banneded
3:29 AM
I did a bb cylinder with a 395 piston, it's alright but that's it. Lighter rotating Assembly is better.
I finally got this saw running decent but I'm afraid of the piston so it's only at 12k.
I believe at 14k it will be sporty.
I'm loading a video now
srcarr52
4:29 AM
Iowa City
I can't see a heavier piston ever being a good thing. Although I like a heavy clutch and flywheel on a work saw. It's a reciprocating thing VS a rotating thing.
Yes, reciprocating doesn't work the same as rotating mass, especially on a system with a crank rod. A lighter piston is always better.
spencerpaving
4:29 AM
central new york
Lil red barn has aftermarket 056 pistons...I have had good luck with those...I tried a 395 piston even wasted a jug doing by machining the chamber flat...I didn't have good results...it didnt run that well...went and found another jug and put a domed piston back in....this is just my personal experience not saying it can't be made to work
Chainsaw Jim
Con Artist LLC
1:29 AM
Springfield Oregon
It will be 98.5 cc's no matter what piston you use,crown height doesn't change it.
Only a increase in bore size or stroke will change displacement.
With the taller crown of a 394 you're adding 5mm worth of volume to the cylinder above the exhaust roof which is more cc's. How many exactly I do not know...I made a guess.
A shorter piston used as a direct fit in the 064 case would leave it the 93cc size.
