junkman
Crush it
- 4:03 PM
- Jan 3, 2016
- pacific northwest
Would a heavier piston be good for a long bar ?
I'm enjoying this thread immensely.......
Today I'm doing a few 3120 carbs.........boring stuff.
I used a 395 piston in my pipe saw. The weight of it slowed the saw down compared to the OEM piston. I didn't realize how much till I went back to the OEM top end.
You can safely take 10g off a meteor 395 piston. Takes it from 117g to 107g, stock 2100 piston is 112g. I haven't weighed a 066 piston lately and I don't have it in my notes.
I can't see a heavier piston ever being a good thing. Although I like a heavy clutch and flywheel on a work saw. It's a reciprocating thing VS a rotating thing.
The only ones I have used were for experiments.Dem BB pistons scare me. I'm afraid they will fly apart.
Have y'all used any that lasted?
Doing pretty good, just real busy!Hello Alan, how are things?
With the taller crown of a 394 you're adding 5mm worth of volume to the cylinder above the exhaust roof which is more cc's. How many exactly I do not know...I made a guess.It will be 98.5 cc's no matter what piston you use,crown height doesn't change it.
Only a increase in bore size or stroke will change displacement.
If he runs a spacer to raise the jug ,does this still apply ?With the taller crown you're adding 5mm worth of volume to the cylinder above the exhaust roof which is more cc's. How many exactly I do not know...I made a guess.
