026 problem
Mkinslow
10:12 PM
Tennessee
Just rebuilt this saw today. New crank seals and rebuilt carburetor. Passed pressure and vac test idles great just want accelerate. Trying too get video up
Mkinslow
10:12 PM
Tennessee
:cursing2::mad:Crap now I’m gonna need help posting a video from YouTube
jmester
11:12 PM
MD
Did you pressure check the carb? Where is you low speed screw at? 1turn from a lightly seated position?
jmester
11:12 PM
MD
Copy and paste the link of your video in the message box and it should work that is how I have done them. But I may have forgotten.
Mkinslow
10:12 PM
Tennessee
I didn’t pressure check the carb. Yes both H&L are out One turn each from lightly seated. It idles fine but when I hit the trigger it just keeps bogging. It’ll keep running if you play with the trigger after it bogs. I’ve got a short video but I can get it to upload
jmester
11:12 PM
MD
How did you set the metering lever?
Mkinslow
10:12 PM
Tennessee
Lol I’ve done it before also. I’m thinking I need to double check and go through the carb again
11:12 PM
What is the extent of the mods/repairs you made on the saw?
Spark screen clean?
Change plug?
Check piston and squish?
Confirm fly key OK?
Which piston size and cylinder?
If all above OK, and you tried without filter, I’d swap the carb out. It sounds bad.
Mkinslow
10:12 PM
Tennessee
Spark screen clean?
Change plug?
Confirm fly key OK?
It’s an all stock saw so far. I got the saw in some trading for other work I did on an 066. It has sat for bout 3 months before I got around to changing the crank seals and doing the carb yesterday. I’ll be messing with it again later this morning after I get back from town and will report back.
