Need splitter, which one?
alfack
5:46 AM
Idaho
Good idea. Yeah. I always have a can of WD40 handy to get the pitch off the wheels and rails. Definitely a must.
Woodpecker
Sassy Madam
7:46 AM
The problem with regular wd40 and other wet lube is it attracts dirt and bark and then it becomes a vicious cycle. Been there done that and don’t care to go back. I urge any SS owners I run into to give the ptfe stuff a try.
Moparmyway
Its just a saw
7:46 AM
In a meeting
I’ve kept a small spakle knife sitting in the rear tire height adjuster square tube to scrape the beam & bearings.
You advice just made me order the Interflon-ishment stuff to try. They’re pretty proud of that stuff ……
:beer-toast1:
Woodpecker
Sassy Madam
7:46 AM
:beer-toast1:
Yeah I keep a small pry bar, 5 in 1 scraper tool, and a small hatchet in that ammo can along with a can of the interflon. I think it works a little better than the wd40 stuff but I’m probably too cheap to buy more instead of the wd40 ptfe stuff. One thing I will say is a little goes a long way once you get all the old gunk cleaned off the machine.
Hinerman
6:46 AM
NE OK
Stainless steel scrubbers work better than a scraper imo. I will have to try the WD40 ptfe stuff, you speak of...
Woodpecker
Sassy Madam
7:46 AM
Really haven’t needed the scraper much since switching to the ptfe lube. Usually only if it’s really wet out.
You talking like a stainless steel pot scrubber or more a bristle brush? I’d like to give it a try.
Hinerman
6:46 AM
NE OK
Yes, the pot scrubber...
