Chainsaw Jim
Con Artist LLC
- 10:54 PM
- Feb 8, 2016
- Springfield Oregon
If you need an aluminum boss welded to the side of the jug, do the fab and send it my way Jimbo.I'm curious how you gonna connect upper handle to side of cylinder?
Stroke and base bolt pattern are different enough to make this interesting & difficult.I am wondering what the stroke difference is if any and if the base bolt pattern is the same or close enough to make it work. Should be fun
Well, this is cool. I just assumed the stroke was diff. Very interested now!The stroke is actually the same and the bolt pattern overlaps each hole enough to make it without a drastic modification. The transfers will not be a problem as the 272 cylinder overlaps the case openings with plenty of room to spare.
I'll find out when I bolt the cylinder down but so far the squish is even looking like it will end up perfect without milling.
To me this is no more difficult than a 440/460 hybrid build....so far.
I'll figure something out with the mounting boss for the handlebar.
Also notice the 52mm ms460 piston in the pic. It doesn't bottom out on the case and laps the exhaust floor by a good 3/16th inch.Well, this is cool. I just assumed the stroke was diff. Very interested now!
I would really like to see what that saw was like. I would never imagine I'm the first to do this. And it sure does suck that I can't find another example to drool over. LolI would consider the Tillotson hs from either same saw, or as long as it has the low idle adjustment. You have plenty of options and I think either could work. Certainly gonna take some work, and as I'm typing this I believe this cylinder swap has been done before, I just can't remember when but believe it was from the Nova Scotia area.
