- 1:10 PM
- Dec 28, 2015
- TN
If finish isn't important use what chain you have. If it's chisel I would go a little less angle than it normally has for longer lasting. It shouldn't dull that fast in those logs. I can get 2 cuts and that was 20 bd ft cut before having to sharpen. If it's still self feeding at the end of a cut I'll start another one if it's short. If it's a 6-10' long cut I'll touch up. If you get the logs elevated and let gravity help you with the right chain all you do is hold the throttle.
