wildroamer
Winning!
- 3:31 AM
- Jan 5, 2016
- Vermont
Gorgeous apple!
Re: Portamill, check Northerntool.com, and youtube videos.We have a few large pines on our hunting land close to camp. We've been considering building a pole barn, or something like it, and I love the idea of doing it soup to nuts with trees from our land.
I like the looks of those Alaskan mills, and have seen some videos on them. Have not seen the porta-mill yet, though I will look for them. Not sure how much saw you need for this type of thing, that's another consideration.
So what size logs and cants, powerhead and bar size are you running thru that Portamill? I (suspect?) larger than the stated 15" max? or is it optical illusion? (But I do see that forklift, LOL)
I use a ported ms660 ,i broke the crank once with that saw,and usef a ported ms460 till i got it back,i only mill softwoods thoughSo what size logs and cants, powerhead and bar size are you running thru that Portamill? I (suspect?) larger than the stated 15" max? or is it optical illusion? (But I do see that forklift, LOL)
till you get to the bottom ,then would hit the groundHowdy buddy. Is it easier to run with the saw flipped up clutch side up? I've never tried it that way but thought about it.
Live-edge TIP: Remove the bark, it often houses bugs/ eggs/ larvaeThese are my first attempts at milling..only about 10" wide. Thicker piece will be used as a live edge mantle, thinner pieces will be a live edge entertainment center.
View attachment 5402 View attachment 5401
Are those rails easy to set up ? Looks a lot easer than a ladder to start with
No, 262 w/ 12-16" logs and Alaskan is quite appropriate. EnjoyAm I crazy to want to use an Alaskan Mill with a 262XP 20" bar ?? I am looking at doing some cedar (shouldn't be a problem) but have some beech and sugar maple I wanted to tie into. 12" to 16" timber. Not full timing it, just wanted some boards for a remote deer blind I am building. Feel free to tell me I am crazy. Only the truth.
