junkman
Crush it
- 9:33 AM
- Jan 3, 2016
- pacific northwest
Forage Farmer's Cedar is not a true cedar like what you're used to.
It's the same stuff we have here, and is a member of the Juniper family.
But we call it cedar. awesome stuff if you can find good logs of it like FF has.
You can remove your bar tip hardware and slab it, then reinstall to get best boardsYou might have a clearance problem with a 20" bar and the larger wood. I have a 24" bar I mill with and only get about 18" effective cutting width with it. YMMV
yes sir its pretty simple really. The angles are simply as follows:
Top plate angle set at 0°
Grinder set at 50° from vertical (40° from horizontal)
Raker depth is set at .045"
Standard chain with a top plate angle gets dull much faster than when set at 0°. this is because the greater angle causes side pressure on the cutters and drive links. This makes the corner of each cutter the primary cutting area, once it dulls, your saws abiltiy to cut becomes greatly reduced. This put a tremendous load on the saws and creates more heat and friction on Bar and chain, thus further accelerating the demise of both the Saw and Bar and Chain.
These modified angles resolve that problem and create a much greater surface area to even that pressure and greatly extends the area of cutting edge being engaged in the wood during the cut. Therefore longer lasting sharpness equalling many more passes before sharpening is necessary. The added .005-.010" of depth guage removal allows for faster feed rate as long as you have a powerhead with the discplacement to provide the torque necessary. I will say that you still need to pay particular attention to feed rate and as soon as you notice a great reduction in that rate, go ahead and dress the chain with a few strokes of the file at that point. Dont let it get so dull that you are using excessive pressure to finsh a cut. This will gaurantee a longer life for your equipment. I have milled several thousands of brdft of slabs and lumber using the same Bar and powerhead without any major incident.
Here is my mill ,northern tool sells themThat's pretty crafty, using a ladder for the rolling element of your mill.
http://www.northerntool.com/shop/tools/product_200325617_200325617?cm_mmc=Google-pla&utm_source=Google_PLA&utm_medium=Logging > Saw Milling + Accessories&utm_campaign=Norwood Industries&utm_content=190610&ci_src=17588969&ci_sku=190610&gclid=Cj0KEQiAl5u2BRC6yszC1_75v5wBEiQAD-hdzwSsrxS11oTD_EzBzXWcKceFmQ_h9YrUhf3d8MND_rkaAs1T8P8HAQ
Here is a great demo vidCan any of you guys post up some pic's, of how you setup for the first cut.
Ive seen some use a ladder as a rail and some use 2x4's or such with a mount on the end of the log.
Thank you fine Sir....Here is a great demo vid
If you do not want to drill holes in a ladder step like he did ,can hold it down with scraps of wood across the steps also ,if the log has a lot of curve ,can shim the ladder on one end with wood so do not waste as much .The wedges are very important as you go ,the slab will start to pinch the bar and mess up the finish on your board without them .Thank you fine Sir....
