malk315
Running Saws for Therapy
- 3:06 PM
- Jan 6, 2016
- Lancaster, MA
Hey Guys-
So our 346XP OE saw that is completely stock has started being a brat to start when cold. I pull the choke and pull to start it several times and eventually it seems to flood instead of popping like it should. Pretty sure I smell gas. Tried with choke in and holding the throttle wide open (pull the trigger and try starting) and that didn't clear it's throat either.
What I found once it gets flooded like this if I leave the choke in and leave throttle alone and pull it many many more times eventually it will fire and quit (no pop). I can pull several more time and it will fire and run a bit longer each time til it finally runs and idles. Let it warm up and it actually runs quite well -- no problems.
Suggestions on what I should start looking at?
I noticed when it finally started if I gave it throttle it would bog and quit and had to really let it get warm before I could trigger w/o bogging. Noticed the carb has a limiter preventing richening it anymore so I trimmed the limiter off so I could richen it a bit more. Next time it was cold the bog was gone when I finally got it running and it four cycles a bit more at WOT and cuts well -- I think it was a bit lean but not dangerous lean.
Oh -- the plug was recently changed to try and help -- no change.
I'm wondering if the coil is weak. i.e. weak so when starting cold with the choke it's not enough spark to pop and ignite the very rich fuel charge a choked carb will deliver.
Any ideas appreciated. Thanks guys.
