malk315
Running Saws for Therapy
- 4:35 AM
- Jan 6, 2016
- Lancaster, MA
I used the Anaerobic Permatex sealant plenty of it relying on sandwich of base to case to push and seal anaerobic
Good luck with it Eric. Generally works real well as long as surfaces are very, very clean. I generally lightly sand, then use brake cleaner (as instructed by Randy).
Wondering who would notice LOL. I didn't get a new impulse line so I made one from the clear line that came with the carb. Same type of line that is on my kids 45 cc scooters. So at least that is now a new line also. Seems like tough stuff and goes on the fittings nice.It looked like you used some clear tubing for the impluse to the carb. Not sure it's characteristics. Usually see heavy black tubing there.
537 18 00-01 Cap
537 32 09-01 Clamp
The early 357 had an auto decomp that was failure prone, to remedy the situation Husqvarna said to replace the setup with a cylinder plug and started producing a "Cap and Clip" to plug the barb on the cylinder. Might be worth a try?
Mornin Dan!That’s great Eric!!
Sound strong, perfect for wood for breaking in, but that looks like ported 262 material there... [emoji33]
That 346 held her own though!!
