Ketchup
Epoxy member
- 3:32 AM
- Mar 12, 2018
- Colorado
Looks like the transfer insert has been modified for more flow. They just sit in there. I’ve glued a few in, modded lots and now I think you can just get rid of it altogether (if you grind the upper).I had a couple of 2511T's on the bench today, one didn't need anything but the other was leaking at the cylinder/base as well as the crankcase itself. I was able to get both the cylinder and crankcase sealed using Dirko HT.
I was curious about this removable bit in the transfers. Slips right in there and the saw was running fine (eventually) once I got it back together. It did not appear to be broken, actually looked like it's designed that way.
I'm not sure who did the port work or muffler mods on these two but they are snappy.
Can anyone explain how to access the fuel lines? They didn't need anything now but I expect one day it will be necessary to replace them.
Mark
The fuel lines are on top of the tank assembly under a plastic cover plate that snaps in. There’s a main tank grommet with the vent spigot and holes for the pickup and return lines.
The other side is mostly molded pieces that fit in and through the carb box. All of it can be removed or installed without pulling the handle. I haven’t seen many problems with fuel lines on these. Just the leaky tank vents.
