Which 2 cycle oil ratio???
lilspenny
5:41 PM
I would stop worrying about that. You cant pick oil ratio based on viscosity. Also be aware that two cycle oil is a mixture and once the solvent flashes inside the motor they are all much thicker.
Detergents as used in oils dont function like you think they do. They dont clean per se, rather they prevent buildup from starting in the first place.
As I told previously no two cycle oil will remove deposits. Running conditions can help as can carb tuning, but its slow process and it may never have any effect
Echo probably doesn't care about there four mix e line enough to give it a dedicated oil as the majority of their line is two stroke.
Well, when looking at the sds and a voa I just didn't see where there could be much detergent. And I know the voa won't show much, if anything... And the sds is not much help, either. Hilarious.. .I think you're probably right about Echo and the lack of an ashless oil.
bwalker
6:41 PM
Montana
FD oils have ash limits and for good reason, so you won't see much show up on a VOA. VOA are not that accurate at low levels anyways. Two cycle oils have every little additives in them, despite what guys think.
The SDS is for storage and shipping purposes. It isn't a ingredient list and it only has to list toxic materials. Some of the things on a SDS may not even be in the product.
lilspenny
5:41 PM
Black plugs are from low load, poor carb tuning or both. Most guys cant tune a carb to save their lives! Its pretty simple to figure this stuff out.
With a 4mix I would run the thing lean to the point you started to have running issues. Its a 4 cycle so you won't burn it up.
BW that's how I always do it. I have a tach for reference but the ear works just as well for that. When I see or read of ope operators who can't perform simple mechanical tasks it makes me think they're in the wrong business. The very idea of spending hundreds of $ every month for shop labor just makes me feel like I'm going broke. I grew up in a farm equipment dealership and we also sold boats, Mercury motors, and ope. I worked on everything.
lilspenny
5:41 PM
Echo probably doesn't care about their four mix line enough to give it a dedicated oil as the majority of their line is two stroke.
BW.... You say can't choose a ratio based on viscosity, and also that too thick can also be bad .. so what are your thoughts on diluting an oil like, say... HP2? Running it at a leaner ratio like 60:1 or 50:1 since it's a thicker oil. What sacrifice do you see when that is done? I have run 50:1 and it seems to run well, run clean... But what is lost when diluting an oil beyond the normally run ratios, such as HP2 @ 50:1 instead of Honda's mentioned 32:1? I understand the obvious ... Less oil... But what about the additives being lessened? Conversely, enriching an oil can have issues. Based on your experience what have you seen, and what are the pitfalls of this? You know, with a br800 scrubbing the piston crown to get a better judgement of cleanliness on a br800 just isn't feasible. You probably don't have a lot of time with a 4-mix and I don't love the design, but I have 3 of them and before I move on I want to finish my tinkering
11:41 PM
Something to be said for that, for sure. But, does it smell good?
All oils smell good to a mechanic, some just smell better than the majority. ;)
bwalker
6:41 PM
Montana
There is no replacement for quantity.
Inbound and have run HP2 at 32:1 in chainsaws. I would not do so in a 4mix.
If your not cleaning the piston you are guessing.
lehman live edge slab
Live Action
5:41 PM
Mn
The statements of shindiawa and stihl co-development of the 4-mix/hybrid 4 was a stop gap because of being behind on 2 stokes I don’t exactly buy. They did this design very purposefully to save on over emissions from the lines to continue to sell the large pro level 2 cycles, if this was to be temporary they wouldn’t continue to use/develop them for the last 25 years. They were designed to be an efficient, quieter 4 cycle that could run at any angle and be smaller and lighter because of no oil sump. I’m betting this new echo revival of the hybrid 4 will just continue down the line and is to save on emissions also so they can continue the non stratto saws. Personally while more complex a 4-mix is smooth and has good torque plus was never designed or was I intended to make it into an actual chainsaw. Like it or not the 4-mix and hybrid 4 aren’t going anywhere and they want clean not too thick of oil it seems. The ultra was developed for the 4-mix because the orange bottle was causing wrist pin bushing failures on the early design 4-mix and as much as anyone hates it works well for this purpose. If Stihl thought it was going to drive warranty pill costs up they wouldn’t double your warranty when buying it.
bwalker
6:41 PM
Montana
Stihl at the time was very much behind Husky/Redmax. Let's not forget that the only way Stihl got Stratocharged saws and Mtronic was from an EU anti trust suit.
Im less knowledgeable on Shindaiwa, but I dont believe they had a compliant two stroke prior to the Echo buyout, so the same would apply to them.
The four mix is a terrible design given its a four stroke with a total loss lubrication system. The worst of both worlds.
Live Action
5:41 PM
Mn
Auto compression release, sweeden has a best for the world clause to share emissions technology that’s why Stihl had the ability to use the technology that husky bought when they got redmax. And it’s a horrible design in your opinion but has been used for 25 years already and not going anywhere in fact I’ll bet it gets more used in the future.
EFSM
5:41 PM
Extreme southern IL
I used to be really down on 4 mix, but my current opinion is that they have some very limited applications where they work fairly well. Blowers are about the only application where they are on par with 2-stroke. Not unrelated is the fact that blowers run the slowest of all 2-stroke handheld equipment.
There are not 4-mix chainsaws and there never will be. Where power to weight, speed, and compactness is all-important, 2-stroke is the clear winner.
ammoaddict
6:41 PM
Granite Falls, NC
Back when I bought my stihl polesaw, the dealer never said anything about a 4 mix . It was not on the tag hanging on it or anything. When I started it for the first time I thought to myself, this thing sounds funny. I thought some kind of weird muffler or something. I got online and researched and found out about 4 mix. I had never heard of it until then. It starts easy and runs good but if I would have known it wasn't a 2 stroke I wouldn't have bought it.
TX_Welder
5:41 PM
SE Texas
Saw a comment in here that H1-R was a poor choice in the 4mix engines ?
Ran it for years in my FS 130 trimmer, my BG56 blower, and my MS 462. Honestly, the trimmer never ran better. Always ran it 50:1. Pretty sure it saved a little husky 350 that I got a little on the lean side. I think if it hadn't been for a good oil, it would have been smoked.
Switched to Motul 800 offroad last year. Didn't notice much difference. The trimmer doesn't start as easy as it did on the H1-R, but the 462 and the blower dont seem to care.
Maybe I've been watching too much treemonkey lately, but I made the switch to Schaeffer this year. And 32:1. Man that seems like a lot of oil. I've never seen an issue running 50:1. I've had my 462 since before dealers in my area knew what they were and it's been as much of a toy for me as a tool. Open air cleaner, wide open muff mod, base gasket delete, (.014" squish") timing advanced. I had the muffler off the other day, and it still looked new inside. Exhaust port was clean. Plug looks good. Was on H1-R it's whole life until last year.
I don't know. Just one guys experience with a couple oils. We'll see what's up with Schaefer now. Mainly bought it for the gallon jugs. My son burns a lot of it in a suzuki LT 80.
