Quzick
Santas little S*itler...
- 4:48 PM
- Nov 7, 2017
- Baltic states, Europe Union
Each axle has there strong and weak points! The dana 60/70 has the best possi in my opinion, if you get 35 spline axels in the hd Dana 60 its a great all around axle. The 14 bolt with the gov-loc is a joke/I ruined mine doing donuts! The axle itself is fantastic with bearing support for the pinion and side adjusters, the factory 35 spine axle shafts are stout so is the ring gear, the possi is no good! Lol there is aftermarket help for that. I have never had a 9” but you can buy anything you can imagine for one! Lol
Run what you brung or build what you want/need!
that 6100 looks like it has a fire/rescue guard on it.
The one I'm my 91 2500 suburban 14 bolt SF is still holding up good lol.Gov locks are weak. The one in my AMA on my dmax is toast!
Lol yep just like saw's run which ever one makes you feel better that's what makes the world go round.Each axle has there strong and weak points! The dana 60/70 has the best possi in my opinion, if you get 35 spline axels in the hd Dana 60 its a great all around axle. The 14 bolt with the gov-loc is a joke/I ruined mine doing donuts! The axle itself is fantastic with bearing support for the pinion and side adjusters, the factory 35 spine axle shafts are stout so is the ring gear, the possi is no good! Lol there is aftermarket help for that. I have never had a 9” but you can buy anything you can imagine for one! Lol
I need suggestion on how to remove broken bolts from aluminum. I have a Kawasaki 680D with a head bolt broken in the block (pretty sure its been broken since factory install) and 3 broken bolts in an Exmark blade spindle. All broken below surface.
I have tried several different lubes, reverse drill bits, heat with torch, drilling and heat, welding a nut to the broken portion (Hobart 180 with heat turned all the way up and letting it cool appropriately) using a battery hooked to broken bolt and ground to aluminum to help break the galvanic bond..... NOTHING!!!!
Neither have enough ‘meat’ around the to support over drilling and tapping or a timesert. Suggestions?
the only one I've split was an easy one to split, I wouldnt ship a crank away for a rebuild without knowing if if the crank is worth it or not. Even in my countries there are companies who rebuild a crank, isnt expensive either.How does one go about changing a rod bearing? Easy? Hard?
I clean my saws also, but I dont live by the saw.I understand fully sir. Need to take care of your equipment though. I do construction on the side and I most always use air and blow off saw dust etc off the tools. Try and keep them running like new.
Guys have to realize. No saw, no work. A little bit goes a long way. Take a little pride in themselves and their equipment. Or someone else's equipment. [emoji106]
I am just optimistically thinking. Lol
But I fully understand what you conveyed. [emoji482]
Hit it with your purse![]()
Has anyone ever seen a plug like this? I havent and i dont know what it is but its in a saw i got a while ago. Just seemed interesting. View attachment 140035View attachment 140036View attachment 140037View attachment 140038
LOL! I wasnt gonna use it. Its inards are actually loose and wiggle. Total junk. It looked interesting though.Throw that gimmicky *s-word in the trash.
FLMAO! Arabian sun gogglesSold at Lowes. One of those gimmicky spark plugs. I threw one in my push mower, was all that was in stock.
