- 3:39 PM
- Dec 30, 2015
- Centre County
I thought those Solo ports looked huge. I had no idea they were over 100cc. Should pull like a GE locomotive!
Liniter screws will definitely bugger the tank if you put them in the bottom holes.
The cure ?
Feels better when cutting too, especially one with these markings on the cylinder
On it’s way @longleaf
Looking good Mike.
What's the best replacement carb for an 044? Can't make this one idle/ tune worth a chit. An hour in the USC pulled Welch plugs etc.... no dice. I'm over it!!![]()
Edit: ordered one from Nate.
Looks really nice Dave!Got the Makita finished up except the uppers. View attachment 135699 View attachment 135698 View attachment 135697
Thank you sirLooks really nice Dave!
Where did your numbers end up?Finished up an Echo CS-800P. I’m quite impressed by these saws! Did a 355T for the same guy a few days ago (modeled after Mastermind’s thread) and was pretty surprised by that turd too.
Cut .028 off the base, cleaned up the squish band, bgd left me at .022 squish. Brought the intake up a hair, the transfers up 3.5 degrees and the exhaust up 4 degrees, widened the exhaust and cleaned up the intake. I also knocked 0.015 off the key to bump the timing.
View attachment 135700 View attachment 135701
Also did a quick down and dirty custom muff mod as he was on a pretty small budget.
All in all i was pretty happy with it. Really does pull pretty damn well with the 24” bar. Yes, the saw is heavy, but it carries the weight very well and is built like a brick-schithouse.
You got a lathe Curt?
I used one on my 440 and had to swap the choke shaft I think.Hd50 for the 461, you may have to swap a rod, can't remember but I know they run very well on them, Dave sells them.
