What's on your bench?
2:32 AM
Looks real nice, just dirty. My 066 looked a lot worse when I got her, but she cleaned up real nice.
T.Roller
2:32 AM
Southeast, TN
I got real lucky today. Got a call from a tree guy that he found another "parts 460" to give me. Told him I can always use parts.
Turns out it is not a 460, but a 12 mm 044. P+C are good, and it has compression. Can't figure why it ended up in the junk pile, but maybe it got crushed before AM tank holders, etc, were out there.
The bearings don't seem to have any play, and I pulled the cylinder and there is some carbon on the top of the piston, and the top of the jug, but the piston looks good (not warn) and the crank looks brand new!
The coil was hanging from the spark plug, and it has a all metal flywheel.
I think I'll do a base gasket delete (and check port timing) and replace the case P+C on one of my Asian 440s.
Did you pop the seals and check the bearings? Seals have a way of hiding bearing play sometimes.
Tor R
Novice, Leg model #2
8:32 AM
Mandal
Got them in the post today, old stock from Germany, unfortantly the piston was wrong...
We had thunder storm today, so I worked a tad on some old forgotten saws, she got another clutch today...
Had to be two years since I swapped carburetor, that was the last time I saw it... seems I had forgotten to adjust the coil lol
Good news is that she is a starter now, may work a tad more on her this fall..
tickbitintn
1:32 AM
middle tn
rattler
2:32 AM
NC
Much cleaner than mine... [emoji846]
What numbers do you shoot for in yours?
(Long bar saw wise)
I left my exhaust low and didn't raise transfers... after a few tanks for break in it feels slow and held back... Exhaust needs to go up along with transfers but right now I am without a 90°....
So it will probably be put back for a bit.
The # on this one are 80 99 118 squish is 22 it probably want see anything longer than a 28 in b/c
2:32 AM
I was going to do that, then I figured no way the P+C look so nice if the bearings + seals were shot. Crank turns smooth (I pulled the cylinder). I think I will just see if it run and go from there.
