What's on your bench?
tickbitintn
8:25 AM
middle tn
I do have a redheaded stepchild blower I leave out under a carport.... Clogged up after a few weeks if it doesn't get fired up...
Customer stuff like that all the time...
I work out of an enclosed carport that is not climate controlled or "air tight" by any means... Sealed up enough to keep the birds out but that's about it...
I'm surprised I don't have more of an issue with it since I have not regularly used my saws for over a year.
You guys storing your saws out in the back yard?
David Young
Safety First !!!!!!
9:25 AM
vt
Learning to braze
385 muffler save
David Young
Safety First !!!!!!
9:25 AM
vt
A fella asked how to bypass a 288 carb Governor
Bigmac
6:25 AM
Oregon
F2F8F1F8-A283-4690-BCC4-B307E972EE80.jpeg 1FC83EDF-677D-484E-901C-D23A7F83DE05.jpeg A82C2EBD-78E3-453A-AC3D-F2B2FCF53B43.jpeg 68595016-2C74-48EC-A1ED-09EE89682A0E.jpeg
Just got my oiling holes and boost window cut into the piston, I angled the window up to directionally feed the boost port, and the final port finish is done, along with port timing set! Now I need to get the heads cut, to set the squish, I have two heads prepped to try on this motor, one is an older head that already had a good squish angle and smaller combustion chamber and the newer head that had the horrible squish band, almost five degrees off angle and a large combustion chambers
8:25 AM
View attachment 127462 View attachment 127463 View attachment 127465 View attachment 127464
What saw is that for o_O
Bigmac
6:25 AM
Oregon
It’s a cr500 engine, getting built for hill climb racing, going Into a newer cr250 chassis, getting a custom built pipe for higher rpm, bigger carb v-force 3 reeds a cr250 ignition and a custom fabric filter set up, it’s going to be fun.. not a saw, but on the bench..
8:25 AM
Nice!
But you could make it is hot saw. Just saying lol.
