What's on your bench?
Canadian farm boy
“Normal” people scare me.
11:34 AM
Ontario, Canada
I don't think there are any pins holes but maybe. I'll find out tonight when I do the pressure/vac test. I did however find out the hard way about how thin the intake is. I had to do a little JB repair. The hole was minor and the JB seemed to fix it up. I'm wondering if the jb repair might be keeping the intake tube from sealing perfectimage.jpegimage.jpeg
Keith Gandy
Maxima K2 40:1 87 Pump Gas
10:34 AM
Provencal, Louisiana
I don't think there are any pins holes but maybe. I'll find out tonight when I do the pressure/vac test. I did however find out the hard way about how thin the intake is. I had to do a little JB repair. The hole was minor and the JB seemed to fix it up. I'm wondering if the jb repair might be keeping the intake tube from sealing perfectView attachment 15276View attachment 15277
1st place ld check. Should hold just fine though
jmssaws
Banneded
10:34 AM
I've ground through there a few times and jb fixed it.
I had a 390 once doing that and I done my math wrong and didn't cut the flange enough and it was holding the cylinder up.
Wd-40 is a much faster way to find a leak,start it with the covers off and spray till you find it. It will be obvious.
Keith Gandy
10:34 AM
Hadnt tried that. Will it idle down when it finds the leak?
