What's on your bench?
Likesaws
9:46 PM
South west. Virginia
A bunch 199 troublemakers.......
All has new K24 HDA kit, and all of them keep preasure and their level is set flush with the body.
2 of them has the same issue, H=1/4 turn
1 of them has a different issue, L=0 turn
I'm tired of them!!!
I think Tree monkey had a fix for these. I saw a thread on this a while back.
Maybe a K22 kit if memory is correct. Someone help out.
One time Randy was looking for these.
Backtroller
8:46 PM
Land of Badgers
Sounds like you're keeping busy. How have you been feeling Tor?
9:46 PM
Brewz
11:46 AM
Hunter Valley - Australia
R
Advance it a whole key or more and try it.
Really?
Will they take that much?
I have a little 024AV with wire mesh filter, dual ported muffler and ported, and a .030 ish advance felt like it did nothing for it.
It's just ... dull.
No real zip to it.
I just had a thought. I ported it using the scored OEM piston and fitted a new Hyway piston to it.
I wonder if the Hyway piston has shorter skirts which has given me excessive intake?
Back to the degree wheel with it
Tor R
Novice, Leg model #2
3:46 AM
Mandal
Is there an alternative i haven't had any trouble with those i can remember.
I always try to stay with 199's, well, as long I got spares
I follow TM's 199 modd, out of seven three didnt worked out well.
thanks for asking :)
In slowly progress, for awhile they thought there where some medecine side effects, result from shoulder MR came and there was infections due work, guess they belive its the main issue now.
Backtroller
8:46 PM
Land of Badgers
This 024 is getting a new meteor. Never seen such a clean saw have so much carbon and ash inside. Should have measured the squish. Must have been very tight. Muffler was packed too. I think he must have run it on water cooled mix.
9:46 PM
R
Really?
It's just ... dull.
No real zip to it.
Hence, my reason for going more. I have about. 020" of key left and it's better than stock. Something has to work, they're dogs stock
9:46 PM
I think my 87-year-old neighbor is just bored this 290 has been here several time's today he said it quit and wouldn't start of course it was out of gas so i cleaned the carb 20170328_174852.jpg 20170328_175038.jpg 20170328_182529.jpg pressure washed it modded the muffler and tuned it up sharpened the chain it's quite zippy with a 16 he tried it and was a happy old fella.
9:46 PM
lol the 290 is a fun toy after being played with mine is a oem 029 motor opened up muffler and 044 carb i run a 325x8 sprocket on it and pulls it nice
I've got a couple of cylinders if this 290 ever dies I'm going to port a 390 cylinder never done one should be fun.
a. palmer jr.
9:46 PM
Southern Indiana
I have a whole garage full of saws now needing work. I do two or three a day normally. I get a dog every now and then that refuses to cooperate...Ever hear of a Hitachi? Someone brought one of those in that won't run, man that carburetor is cramped in there!
Woodrow
Reynolds Crane - Home of Ported and Polished Saws
8:46 PM
Wisconsin
I just completely went through this low hour 2005 357xp I found on Michigan Craigslist about 6 months ago. It needed a few little parts, deleted the base gasket (squish is .023), put on a new caber ring (compression is 170), put on a new muffler that was modded by Laslab John (it came on my like new 357xp that I had ported by Mastermind) and a complete cleaning top to bottom. I have not fired it up yet because of picture #4. What did I miss? I know they are not the wrist pin circlips, I checked to be sure when I put the cylinder down with 518. They measure about .031 in diameter.
bretts
1:46 PM
New Zealand
These are on my bench
Under my bench is a Jonsered 535 in pieces, Jonsered 2036, Echo 400evl, Echo 302 and a Stihl 011av.
T.Roller
9:46 PM
Southeast, TN
View attachment 63418 View attachment 63419 View attachment 63420 View attachment 63421
Those are wrist pin circlips lol
