X 66 stang347 X
- 8:10 AM
- Sep 23, 2016
- Georgia
My car has 4 of them bastards. Only time I've pulled them is when I installed 4.44 gears
Yeah we wouldn't want those silky smooth jug manipulators tore up.[emoji16]you can do it while your on the outside of the wheel well grab the outer joint and wear gloves so the clamps and rough areas of spindle dont tear you up
I'll wrap a chain around it and tie something heavy on it. Then I'll pop it a few times like a slide hammer.
Can't get the tractor to it Ross.
YesI gave a 22 yr old guy a ride that has only taken public transportation his whole life. Did a quick launch but had launch control set to low at 4500. Want to see the vid
sureI gave a 22 yr old guy a ride that has only taken public transportation his whole life. Did a quick launch but had launch control set to low at 4500. Want to see the vid
Might have a bit of spline wear . Turn it backwards and forwards and pull.
I miss my Mustang.Found this vid also. My son on his atv
If your old today you'll just be older tomorrow...just sayin![emoji6]I'll try that Dallas. It was dark, and I am old.....but tomorrow will be a new day.
Ok.....I got the axle out. @dall 's idea didn't work, inner cv joint just slid apart.
I pried on it with a 2' bar, no joy. Then I ground a couple of pieces of rebar to make a wedge. Just a few taps, and she popped right out.
