What's on your bench?
beaglebriar
The Peanut Gallery
9:54 PM
Warren Center, PA
I usually have no problem tuning but this one is real finicky. I thought I had it just right but apparently not. Doesn't take much for it to be off.
I'm working on a J red 535 right now with the same issue. Just did a complete rebuild and leak down test was good.
I'll be pulling it back apart to recheck everything and possibly a carb swap.
Some saws are just a pita and this is one of them.
cease232
9:54 PM
Montana
I'm considering it. I'll have to see if I have another SDC carb to mount up.
Mattyo
Youtube speciawist
9:54 PM
Farmington, CT
@Mattyo got me fixed right up. The low end is still pretty finicky though. Very narrow range between just right and flooding.
I had the same issue on a 372 ... used AM carbs, both were finicky ... used an oem carb and it tuned fine. I dunno what it is about the am carbs, but they just didn't flow right at idle. wish I could figure out that issue... anyway, you may need to swap out the carb to get it to run ...not finicky. :)
btw, i take no credit for the idea... @jmssaws is the man
jmssaws
Banneded
8:54 PM
Have you checked the pop off pressure?
Finicky low is generally not enough pop off.
Mattyo
Youtube speciawist
9:54 PM
Farmington, CT
ie, needs a stronger spring on the needle? ie, stretch the spring a bit?
cease232
9:54 PM
Montana
After running great last night It was a PITA this morning after sitting. I'll test the pop off and try to shim it today. Will report back later. Thanks Jim.
cease232
9:54 PM
Montana
Checked pop off pressure, seemed to be around 20psi. Also found a small leak on the inlet seat so I replaced the needle with the old one and the leak resolved. Anyone have any idea what the pop off pressure should be? I did shim the spring about 005.
After all this the saw gave me even more fits. I read you can damage the diagram checking pop off. Wondering if I put to much pressure on it.
jmssaws
Banneded
8:54 PM
20 is about normal
I generally raise it 2 to 4 pounds
