What's on your bench?
1:40 AM
PA Dan
FYD
1:40 AM
White Oak PA
Collection of 550 cranks, all with blown con rod bearing.
Tor R
Novice, Leg model #2
7:40 AM
Mandal
4 out of 10 Dan
It's their weak spot, I'm not sure of it's the con rod bearing who is too weak or if it's the uneven crankcase halfs who doesnt line up everything 100%, or if the strato play a part also.
I have no problem with a lean scored saw but it always make me nerveous when those cranks get blown.
Simondo
6:40 AM
UK
4 out of 10 Dan
Tor...I Think Randy has a Very plausible theory in that the bottom end is not getting as much oil as it could need . 50.1 may not be enough with some of these saws.
12:40 AM
4 out of 10 Dan
They run too lean......then recommend a 50:1 ratio.
Member
12:40 AM
Has anyone here ever tried taking saw cranks apart before? I know it's not standard procedure, would seem someone would give it a go though. On larger two strokes it's not even a second thought to change the bearing and save the crankshaft. So is it just economic factors weighing in here?
1:40 AM
I've done few dirt bikes and it wasn't easy seems simple but specially tools were needed.
Member
12:40 AM
I made a jig to do 066 cranks. It's time consuming to get rid of the run out.
Never done it myself, does sound intriguing to me though, a cousin of mine "sets" the cranks in a lathe with a lead hammer.
So I guess my question of the day would be, where would a person source the bearing, if it's not supplied from the manufacturer?
Tor R
7:40 AM
Mandal
there is a few companies who do that type work, the price tag I got wasnt bad at all in Norway.
If I first go that path I defently want better bearing then what Husky has used.
rattler
1:40 AM
NC
Sometime when you have an extra minute or two, could you post a picture of your jig? Kind of interested in what you have. Guess that makes two questions.
Stump if you press one apart how about some pic,s my press wouldn't press a 385 apart but I dident have a good way to hold it.
Member
12:40 AM
Next time my cousin comes over for coffee, I'll ask him to let me in on his voodoo crank work and do up a thread on it. I'll also ask what he holds the crank with, all I can remember being on his press are lots of different blocks of heavy steel.
