What's on your bench?
Simondo
1:11 PM
UK
Let's switch gears check out this plug
Eco saw....minimal usage of fuel or oil !!! danger ...
X 66 stang347 X
8:11 AM
Georgia
Guy came in this morning with ms250 and said he had a case of the tight rope. Found straight gas in tank. And After I showed him he said keep it. I have a extra engine laying around I'll put in it. That's 2 in the last 3 days straight gassed IMG_2100.JPGIMG_2099.JPGIMG_2101.JPG
Simondo
1:11 PM
UK
dont know if they have Aspen over there, it's defently the most used fuel used on JRed/Huskies here
I didnt know that Tor..any alkylate fuel can fool you to some extent if you are not used to the result.
Tor R
Novice, Leg model #2
2:11 PM
Mandal
I didnt know that Tor..any alkaloid fuel can fool you to some extent if you are not used to the result.
you get lots of problems if you swap from Aspen to pump fuel or the other way, most people here prefer Aspen because there is less maintance cost compared to pump fuel
I wonder how this new bio fuel will be for us, on start lvl now.
Simondo
1:11 PM
UK
Swapped a 550xp and a 346 NE over to Aspen and all went ok. What are you finding are the issues Tor..
I tested for Ethanol in my local filling stations pump fuel recently and couldn't detect any ,I dont have fuel problems with my saws .
Cut4fun
Redneck Chainsaw Repair
8:11 AM
Ohio
Stripped the 475 all the way down to where the crankcase could be split. Not going to use the right half anyways as it was the half I had to redneck repair.
Will use a 445 crankcase or other 475 cc. All I want from this 475 was the good crankshaft for the 445 or other 475. All the parts put in a bin and shelved.
Still havent come up with anything to fit this freaking worm gear. Guarandangtee ya no freaking worm gear will be going back on with the nos 475 seal and bearings. Will all be updated bearing seal and oiler system from the 505 445 425 stuff.
