What's on your bench?
beaglebriar
The Peanut Gallery
12:51 AM
Warren Center, PA
Sent the Arctic cat that had transmission issues back home today. It's all better now and hopefully someone learned their lesson.
Now I have a little echo 290 and an 044 on the bench. Life is good again![emoji3]
Tor R
Novice, Leg model #2
6:51 AM
Mandal
One of the things I bought today is this 390 clamp, same clamp as JRed 2188/2073/2081 use, this clamp has perfect dimension for 340/345/346/350/351/353/357/359 intake. Just checked it and it fit perfect.
Here is one xpg part, it is used on 346/353/357/359, and probleby on 362/365/372 also. This sleeve who I never have figured out part number to goes from the tank to the fronthandle and an inche into the fronthandle, it is to prevent wiring issue on that weak spot.
I've done a few other things, like molesting those jugs, defently not a pro job, I may tight up the corners a tad more and see if I can straight up the roof a bit more on those transfers.
Btw, my first porting.
NE timings: IN 77, TR 123,124, EX 106
OE timings more ??? so far :D
exSW
'Cause Thomas is a poopyhead
12:51 AM
United States
I've never used a heated handles saw either. I got a jonsereds 820 with heated handles from esxw that I need to put together. Just need a crank. The con rod bearing has a small crack in it. Couldn't feel any movement until you got it in the right spot.
Ahhhh man! I didn't catch that.
t4driller
Daddy Day Care
12:51 AM
Southwest pa
That's ok, It took me awhile to notice it also. It would only do it in 1 spot. Turn it a tiny bit and it seemed fine. Took about 30 min with flashlight to see the crack
t4driller
Daddy Day Care
12:51 AM
Southwest pa
I think that's going to be an awesome saw when its done.
I think so to. Was hoping to have it done before the pa gtg, but haven't had time to do anything. Still need to get a crank. I did find all new av mounts, gaskets/ lines, seals and mesh air filter in my inventory. I have a case here with a crank I just found. Gonna see if it has the crank I need in it.
Glock37
12:51 AM
Monroeville Pa
Just got done with mine added the dogs and decal damn theres a lot of little psrts on these
