What's on your bench?
DSS
widebody
3:37 AM
canuckistan
Had an opportunity to mess with a 034 super I purchased a while ago. Owner stated it was just a frustrating saw. Would start and idle ok...but would bog down upon throttle...and would only work with a full to half tank....
Pulled the carb apart...it was dry...but should have taken a photo of it. Looks like I could have started a fire with the amount of wood fibers that were blocking the screen...so I looked in the tank for filter....
I got a nice 625 jred the same way. It wouldn't run at all. No filter and carb full of sawdust. New 20" b/c. Still have it.
$25
PA Dan
FYD
2:37 AM
White Oak PA
Those 346 xpg's wasnt that bad, both should actually had scored top end, both G systems are inside normal value :) None of those where abused.
The one to right where carbon scored, need a new piston, or worse a new p&c, other then that it's a decent 2007 model, it will go to someone very soon :D
The one to left where okey, not that pretty in plastic parts as the other one, all it need is carb clean, oh well, it will get one 199, hate those zama's anyway.
This is how the G wiring goes on all those 346xpg's, generator & rear heat wiring goes to that spot, from there and out to the handle I normally use an insulation sleeving, the sleeving also go through the handle. It do prevent any issues with the wiring.
Awesome work Tor!
Chainsaw Jim
Con Artist LLC
11:37 PM
Springfield Oregon
Could you fit a spring over that screw to help it from not backing out or in?
I'm sure it would work if I wanted to find the right size, length, and tension. There is an excessive amount of vibration with the 075/076 at high rpm so nothing likes to hold.
This method of using loctite keeps it hard to turn as if there is a little plastic strip in the threads.
Tor R
Novice, Leg model #2
8:37 AM
Mandal
Those went in the freezer, 550 crank + bearings, and 242 bearings. Work for tomorrow.
Did anyone thought I love those classic 242...I think I've sucked Norway dry for them :D
Some think there was no difference between 242 to 242 XP, pay attention to the bewel.
1989 jug, non XP
242 XP jug
Chainsaw Jim
Con Artist LLC
11:37 PM
Springfield Oregon
Tor R
8:37 AM
Mandal
Is the intake floor higher on the xp cylinder?
I sized them, couldnt see any difference in timings, but since there is almost no bewel in XP jug everything open and close more tight on XP compared to the older jug.
Piston is also different, bigger windows in XP.
I have one 89 without gasket and one 95 xp who has the gasket, the xp has always been more snappy compared to the one with higher compression
bigbadbob
11:37 PM
Interior BC Canada
Definitive Dave
Piss Rev Mafia Member
2:37 AM
Central Ohio
