What's on your bench?
CJ Brown
I learned it from a hockey card...
11:17 AM
Belleville, Ontario, Canada
Partner
5:17 PM
Poland
and if they can withstand the tests, how long
AlexStromberg
Epic gamer
5:17 PM
Sweden
Have you tried those bearings before? I'm curious to know if the seals will actually hold pressure and vacuum. There was a retailer here that had a similar bearing for sale that showed promise but the seals weren't up to the task unfortunately.
Havent tried. The seals arent NLA from Husqvarna here so will most likely get the oem ones.
Partner
5:17 PM
Poland
Continued poulan xx the saw fires because I covered the crankcase hole, but the manual oiler will not work? how is the hole in the line to the oil tank
David Young
Safety First !!!!!!
11:17 AM
vt
Bil 357. culprit?
broked cat moofler. And No heat shield.
CJ Brown
11:17 AM
The pto side seal seems to be NLA here in North America (and has been for a long time) but the flywheel side is still available here. Can you still get PTO side seals in Sweden?
Agent Smith
Hack of all trades
11:17 AM
Northeast ohio
Moved a bunch of clay in to raise grade and build a little makeshift retaining wall out of whatever I could find in the scrap materials pile. That little wall is against a natural waterway that runs through my property that only flows when it rains or snow melts really. Wish it was continuous but the ducks love it and it helps wash all the duck crap away when its flowing. Also started building the 4x8 chicken coop. 346 with the cheap chain was on stump duty today. Time for a buschhhhhh and some saw cleaning and sharpening
Stevetheboatguy
10:17 AM
Nw IL
John deere orbital pump........
Stupid weak azz design.
4hr almost 5 to remove weld and reinstall......
Would have been nice if it was welded at the factory. It was originally some type of braze. But seeing how it wouldn't have been wise to disassemble. It got a million ss tig tack welds to keep the heat down.
Tac & cool tac & cool tac & cool. Even using some shop air to help the process. Still took almost a hour........
Can't rush some things.
Steven
Partner
5:17 PM
Poland
I added a few small parts, I corrected the threads on the starter cover, I have to buy a 3/16 tap for the air filter cover. The saw stood for a long time because there was only oil in the tank and carburetor, the chain and guides had to be rusted :-)
