- 12:51 PM
- Jan 28, 2016
- Dike, Iowa
Omc outboard recoilHere's a shop tip that nobody remembers or they weren't taught.
One of my biggest pet peeves is recoil ropes that pull out because of a slipped knot.
So after you melt the rope and smooth it out for ease of installation. You tie your knot and ship it. That's where the problem is. That slick and smooth end will ruin your day when you least want it to. What I do to eliminate that issue is re-melt the end after the knot is tied and flatten/bulge it out with the backside of a pliers or screwdriver. Makes it nearly impossible for the knot to slip out of place then.
View attachment 286384 View attachment 286385
Simple enough?? Must not be....... Nobody does it.
Rant/tip over
Steven
How did that happen? Was there a keyed clutch on that, without the key?Next up is this very early 7-10. Low hours but very dirty and the crankshaft is chipped under the clutch.
Mark
I don’t know dick about them old macs but they are always interesting and tell a story. Seem to be tough as hell. Some folks are good and tearing things up though. If a guy can fuk up a ball bearing with a rubber mallet i suppose and old tough Mac didn’t have a chance unfortunately.How did that happen? Was there a keyed clutch on that, without the key?
Thank you for sharing that information. I don’t like to pester people for knowledge but I always appreciate it when folks share!Yes, keyed clutch with RH nut. It had evidently been run loose as some point and cracked off a piece of the crankshaft that went 1/2 way around. Good news is the 70 cc saws share the same 1.375" stroke crankshaft with the 54, 57, and 60 cc saws so I have a lot of options including finding one without a keyway that has LH threads.
Mark
inAlso had to replace spindles one the beast![]()
Hell yeah brother can't wait to see this one! What size bar and wood?Test drive tomorrow. View attachment 286851View attachment 286852
Gonna run the same bar and chain I used on the 357 and in the same wood. 7T rim, 23RSP, 20” barHell yeah brother can't wait to see this one! What size bar and wood?
