Whats on the Grill or Smoker?
Mycamaro_68
By guess and by golly
3:58 AM
Cedar Rapids, IA
Looks good. Pull that bad boy at 205-210 internal temp and good to go…let it rest wrapped for an hour or so, slice across the grain and be some fine eatin’.
Just pulled it off the smoker. It was probing at 203-209 degrees and felt nice and tender. It's in a cooler taking a nice rest until about 11:30 or so for some hopefully amazing lunch!
USMC615
Fapper Fi
4:58 AM
Mid-Georgia
…will make for some fine eats no doubt!
Mycamaro_68
3:58 AM
Cedar Rapids, IA
Brisket turned out pretty good. It is tender but kind of like pot roast is tender but slightly dry texture. Doing that big slab of meat on the pellet grill I wasn't able to position it any other place than directly above the flame which overcooked some of the meat on the underside. Next one I think I will try to shield that hot spot. Flavor was great though!
srb08
Doesn't play well with others
3:58 AM
Mid Mo
Brisket turned out pretty good. It is tender but kind of like rot roast is tender but slightly dry texture. Doing that big slab of meat on the pellet grill I wasn't able to position it any other place than directly above the flame which overcooked some of the meat on the underside. Next one I think I will try to shield that hot spot. Flavor was great though!
I use another grill set on bricks to get the meat farther from the heat. Works well.
crowslayer17
3:58 AM
Iowa
Thanks guys. Looks like you all got some great eats!
ElevatorGuy
It’s up and down ;)
4:58 AM
Maryland
Brisket takes forever at 225°. I did my last one at 275°, this pic was after it hit 160° I. T. And wrapped after. Took 9 hours total.CF6453E7-FDA2-4EF8-8392-953934BDC7CA.jpeg
Hinerman
3:58 AM
NE OK
That looks amazing in my book!!!
Hinerman
3:58 AM
NE OK
What temp do you guys cook your brisket at?
180 for 4 hours; then turn grill to 225, when the internal temp of the meat gets to 160, I wrap meat in foil and turn temp to 250; when the internal temp of the meat gets to 190, I remove meat from smoker and place in ice chest for resting time of at least 30 minutes.
This is a Smokin' Brothers recipe; the same place I bought my smoker...
