Good Place for ATV Repair Info?
Clarkbug
1:57 PM
Northeast
Just curious if anyone here has a go-to forum that they would use for ATV questions/information.
We were given an older Yamaha Moto4 by a family member a few years back, and it needed some TLC. Its up and running again, but makes a kind of knocking or clunking in the rear when you ride over bumps or push down on the back end. Doesn't seem to be impacting anything, but I am worried there is something I need to address before it grenades and creates an expensive problem. Wanted to find a spot to ask for input instead of just starting to tear things apart and hoping to find a smoking gun.
RCBS
Redneck Savant Extraordinaire
1:57 PM
Ohio - The hilly part
Don't know where to tell you to look but I used to thrash one of these back in the early 90s. They'll go up hills you wouldn't believe. lol
Clarkbug
1:57 PM
Northeast
This one was used mostly as a utility wheeler by the original owner, then passed to my BIL that was...less than kind to it. Apparently he didn't realize that the screen in the air box is just there to hold an actual foam filter... And he tried to fix an issue with the starter clutch by taking the case screws out with a regular screwdriver. So, I got a little bit of a box o' wheeler for the cost of moving it around if I wanted to try and fix it. Some eBay parts to the rescue, and it runs and drives. I will say it does NOT like to start when cold at all, so Im wondering if I have an issue with the valves, cam or if its just low on compression. Need to put a tester on it and see if I need to do a top end. But would like to figure out my mystery clunk in the rear first before I spend too much more on it. Seems like a well made, easy to work on wheeler.
legdelimber
1:57 PM
N.C.
Never owned any 4 wheeler stuff.
But If I were to walk up and try to find the issue, this is just what I would start with first.
Lets look at the common stuff related to suspension.
Shock absorber bushings. Cracked or Broken mounts for the shocks.
What sort of linkage or swing arm caries the axle?
Is there a differential housing that could be cracked?
Any chain guard or cover parts that might be loose?
Again, look at all pivot or flexing pieces.
Do any bearings seem to be sloppy?
Wheel hub and bolts or lugs, etc loose?
Perhaps a cracked rim.
Broken exhaust mounts letting something bump?
Where are you pushing on the machine?
Any body panels, fenders or seat loose, etc, that might be moving and clunking.
Heck even handlebar mounts and such.
Then look around for something that might be loose or bent and possibly touching as the suspension goes through its travel.
edit: If need be, get a friend to help push things while the other person looks at the machine.
Just be careful and don't get your fingers or your head pinched while anyone pushes on the machine.
legdelimber
1:57 PM
N.C.
One more that I missed.
apply either the front or rear breaks, separately and the while you push the machine
Take notice of if the sounds, each time you change from front or rear brakes.
Also try it with both front and rear applied together and notice if things change.
does having it in gear But not holding the brakes make a difference in the sound?
Bill G
12:57 PM
What year is it? Post a pic of you can.
bucketofguts
1:57 PM
north carolina
My 2003 Kawasaki Prairie 650 , 633 cc. I have a Warn winch on the front. Many internal mods. Back in the day. Have a look.We would drag race one weekend, ride 100's of miles around Welch WV with the locals the next. Mostly trails where we would not see anyone else. Glory days!
RCBS
1:57 PM
They built them simpler back then. Honestly the Moto 4 is just a TriMoto with a different front end on it. Suzuki also used this approach in the early years. I consider late 80s and early 90s quads to be nearly bomb proof. Big Bear, Honda 300 and King Quads are some of my favorites. Wouldn't hesitate to buy a well kept one today if the need arose.
bucketofguts
1:57 PM
north carolina
You need a true guru that works on ATV's. One that can fix a Honda's auto styled tranny, or a CVT w/o batting an eye. They will be backed up weeks or better. I still have my ATV guru, but lost my chainsaw main man that would drop what he was doing and take a look at mine. He was only 87. Fell in the bath and was hurt pretty bad and gave it up. Good luck to ya! Cool vintage ATV by the way!
Clarkbug
1:57 PM
Northeast
Well thanks for all the responses here. I wasn't sure how much traction it would get, but very much appreciate having more minds put together to help me figure things out.
This is a 1986. I don't have a photo handy, but will snap one later today or this weekend and will put it up here.
The big problem (if it is one) is this clunk. Ill try some of legdelimber's ideas and will see if that helps narrow it down a little. Since this is a shaft drive machine, my first thought might be that the splines on the driveshaft need to be lubed, the Ujoint might be done for, or that maybe its the swingarm bushings. I would put some new shocks on it, but these are NLA and I am willing to bet used ones are probably in the same boat.
The smaller problem is that it doesn't start when its cold, and I noticed a fair bit of spit back out of the carb (fuel in the air filter). I am guessing I am low on compression and its either a dusted ring/cylinder, something up with the valves, or a combination of both. Just did another oil change on it and got some more sparkly bits out of it from when the starter clutch exploded, so hopefully its got a fighting chance from here on out.
Will be back when I have some time to do all little more troubleshooting on it.
They call me Mr. Kibbs
1:57 PM
Wandering the VA woods
I used to frequent an ATV forum about 20 years ago when I had some '01 Rancher issues. I think it was called ATV Nation, but like so many forums it got all jacked up by hackers. I think this is what it evolved into, but cannot be sure. Used to be a bunch of very knowledgeable and helpful folks.
Basher
2:57 PM
Canada
All the suspension bushings, upper and lower eventually wear out and need replacement, they take a lot of abuse, of course so do the shocks and the suspension springs, all these parts make noise when worn and flexed. Most of my friends and I run Honda or Can Am quads, the Can Am parts are less expensive for the most part but the Can Am`s are known be be much more involved to work on meaning they were not designed for easy access for most common maintenance, parts replacement and procedures.
Clarkbug
1:57 PM
Northeast
Sorry for the delay here everyone. You all came with good ideas and I left you hanging. Here she is in all her glory.
Went out and shook and jumped and wiggled. For sure found a worn bushing in the front, so that's one place to start. Still sounds like it might be a swing arm bushing or maybe the u-joint or splines need some lube, but can't isolate that. I guess I'll have to see if that's something that you can service according to the manual.
Now to see if there are any replacements available for the bushings in the front...
EFSM
12:57 PM
Extreme southern IL
You should do a valve adjustment. I’ve seen valves already get tight and make them start hard.
Basher
2:57 PM
Canada
The bushings and both ends of the shocks have the most potential for clunks from movement, the driveshaft and slider splines have more potential for clunking when the tranny gears are shifted. I jack the bike up and get the wheels off the ground then grab and rotate a tire forward then backward to test the differentials, also check the diff. housings for fluid by removing filler plugs to make certain there is gear oil in them, should be full to the plug opening and not discolored from water ingestion.
