Whats on the Grill or Smoker?
MtnHaul
6:58 AM
West Coast Mtns.
For $13/lb midgrade slow elk, least they could do is spend half a minute trimming.
It must've been a slow elk if it's on your grill now.
Isn't that extra bit of fat basically a "fat cap" that helps baste the meat during cooking? I know the fat prevents seasoning from getting to the meat but it does add some moisture. I recently bought some tri-tip untrimmed and I did have to thin out the fat cap but what I left behind sure was tasty.
Sloughfoot
6:58 AM
Norcal
More common to remove it than not, I think. It's not there on most of them I buy. Any marbling at all and there's enough fat inside to moisturize/tenderize if it's cooked slow.
For how little smoke this Lazzari Mesquite produced, it added a lot of flavor. It was half the price of Kingfords at the little country grocery store I got it at.
MtnHaul
6:58 AM
West Coast Mtns.
Yeah the Lazzari does not produce a ton of smoke by itself so I usually add in some hickory or apple depending on what I'm smokin'. Some of the best burgers I ever cooked were over Lazzari with local Coastal Live Oak mixed in--delicious smoke flavor.
Sloughfoot
6:58 AM
Norcal
Yeh, Live Oak might be my favorite.
cuinrearview
Handy dood
9:58 AM
Dowling, MI
View attachment 486869Bacon wrapped ravioli on the smoker. According to my wife they are very addicting.
Pasta pre-boiled? Just wondering how it stays tender in the dry smoke. Looks fantastic. My wife has been talking about doing a round of pasta, and some lemon ricotta ravioli is usually in the mix. Probably ask her to do something heavier for this.
stihl livin
Do the Dallas
8:58 AM
Upper Midwest
Here is the recipe.
Bacon Wrapped Ravioli on Traeger
Smoky, crispy bacon-wrapped ravioli bites — a perfect Traeger appetizer with a cheesy center and irresistible smoke ring.
Servings: 6
INGREDIENTS
24 pieces large cheese or meat ravioli (fresh or thawed frozen)
12 pieces thin-cut bacon strips
2 tablespoons brown sugar
1 teaspoons black pepper
0.5 teaspoons garlic powder
0.5 teaspoons smoked paprika
0.3 teaspoons cayenne pepper (optional, for heat)
1 cups marinara or ranch dipping sauce
STEPS
1) Preheat the Traeger: Preheat your Traeger to 275°F with the lid closed. Cherry, apple, or hickory pellets all work great — cherry adds a subtle sweetness that pairs beautifully with bacon.
2) Make the seasoning rub: Mix together 2 tablespoons brown sugar, 1 teaspoons black pepper, 0.5 teaspoons garlic powder, 0.5 teaspoons smoked paprika, and 0.3 teaspoons cayenne pepper (optional, for heat) (if using) in a small bowl. This sweet-savory rub will caramelize on the bacon as it smokes.
3) Prep the ravioli: Use 24 pieces large cheese or meat ravioli (fresh or thawed frozen) that are fresh or fully thawed — pat them dry with a paper towel so the bacon adheres well. If using large ravioli, cut each bacon strip in half crosswise. Wrap each ravioli snugly with a half strip (or full strip of 12 pieces thin-cut bacon strips), overlapping the ends underneath so they stay secure.
4) Season: Lightly sprinkle the seasoning rub over all sides of the bacon-wrapped ravioli. Place them seam-side down on a wire rack set over a foil-lined baking sheet, or directly on the Traeger grates.
5) Smoke low and slow: Place the rack directly on the Traeger grates. Smoke at 275°F for about 45–45 minutes
, until the bacon starts to render and the ravioli are heated through. The low temp lets the smoke penetrate without bursting the pasta.
6) Crank the heat to crisp: Increase the Traeger temperature to 375°F and cook for another 15–17m 30s
17:30, until the bacon is fully crispy and caramelized. Watch closely in the last few minutes — the brown sugar can go from golden to burnt quickly.
7) Rest and serve: Remove from the Traeger and let rest for 5 minutes
Serve with 1 cups marinara or ranch dipping sauce on the side for dipping.
NOTES
Pellet suggestions: Cherry or apple for mild sweetness, hickory for a bolder smoke flavor.
Ravioli tips: Fresh refrigerated ravioli (like Rana brand) hold up best. Frozen ravioli work too — just thaw completely and dry well. Avoid ravioli with very delicate fillings that may leak.
Bacon tip: Thin-cut bacon is key — thick-cut won't fully render and crisp in the same time it takes the ravioli to cook through. Toothpicks can hold seams in place
Make it a meal: Serve alongside a smoked tomato dipping sauce or even a drizzle of hot honey for a sweet-heat finish.
