Member
7:08 PM
Any thoughts on Kawasaki K-tech oil? Thanks
I run it, it's the same or similar to Husqvarna XP oil, has fuel stabilizer already in it, is a blended oil, blue in color, usually quite affordable when found and performs well for me @40:1.
sawmikaze
8:08 PM
steeltown
Tired of measuring your oil? Don't know when to use 32:1 vs 50:1??
Take out the guess work and
JUST USE 70:1!!
At least it's easy to use 2 for 35:1
BTW my Echo bottles had consistently just under 2.5oz, so either my measuring cup is off, or they're shorting me.
Funny you mention that...
When I was mixing last week a 2.5 gallon red armor bottle only measured out around 60:1 when I dumped it in my ratio rite.
Cheaters.
brandonstclair20
8:08 PM
Starkville
If things turn out as planned, I’ll need to buy a gallon of 2 stroke oil. I’ll either buy that or a gallon of Klotz super techniplate.
7:08 PM
Saying what oil you use is like saying you banged someones wife. Damn, its all serious and stuff.
It doesn't have to be that way. I've tried a hell of a lot of different oils. After modifying a hell of a lot of saws, I've yet to fry one due to the oil.
The oil I keep coming back to?
Yamalube 2R
Member
7:08 PM
Would be interested in seeing what you get after you compare pricing. I've had saws with this sitting in it for well over a year and it's still just fine to run and no fuel system issues. This being in old antique, brand new and ported pro power saws along with other ope that gets seasonal use. Also starts easy in the winter time, being a blend. I like to keep things simple, easy and working, this oil does that for me. Going through fuel like I do, being cost effective isn't a bad thing either.
Don't ask me how it smells, I don't huff exhaust or anything else for that matter.:confused:
8:08 PM
We can kick it into high gear if you want to...
kingOFgEEEks
8:08 PM
Tioga County, PA
OK, I'll bite.
I run Mobil 1 in my wife's van (0w30). I drain it at 5,000 miles, and use that to top off the 350 in my old square body. Unfortunately, I don't drive the square enough to burn all of the drain oil that the Sienna makes.
So, what ratio should I mix used 0w30 to use in a modern chainsaw? Do I need to mix it thinner if I'm using an AT/MT saw?
Adirondackstihl
8:08 PM
Upstate NY
OK, I'll bite.
I go at least 10k on Mobil 1
8:08 PM
I used to go 15,000 on Castrol Full Synthetic, but I was driving over 36,000/yr back then. That was in my 92 T Bird SC, and I got over 250,000 miles on it!
I drove it so hard (I went through my divorce then) the keyway in the crank that held the crank sensor gave way!
The engine and drivetrain in that car were tough as nails (a SC V-6 w/5 speed manual), but I bent the crap out of the 5 speed shifter cause it would not shift fast enough (was a Mazda Truck Tranny). The guy in the tranny shop stated "he did not understand how these things got bent". I responded "I did"!!!
Bjorn
5:08 PM
Sweden
Cool down a little or do you want to divorce from your car too?
Castrol is a very good oil
kingOFgEEEks
8:08 PM
Tioga County, PA
Evansaw
3:08 AM
Greece
Not too long ago I ordered 2 gal of AMSOIL Saber (to get free shipping) and split the cost with a friend (1 gal each).
IMO, mixed at 40:1, it provides excellent protection, and I run it in all my 2 cycle stuff.
Exactly i am really amazed by 1:40 Saber nothing comes close from other oils here
