jake wells
no longer here
- 10:35 AM
- Dec 28, 2015
- ky
pecker? i pack a shovel instead
I have a maul. It's always hard.pecker? i pack a shovel instead![]()
Forgive me for asking this, but if you can get the oil to ignite completely in your mixture during combustion would it not give you more power at the crank? My thought is that oil in the mix would have more potential power per unit compared to a unit of gas in the mix.
5:1what ratio do i mix this at
Don't run that stuff! I tried with disastrous results.what ratio do i mix this at
Maybe 2:1 if you've read all these posts.what ratio do i mix this at
K2? Dumonde? Old Charter with bubble gum flavor?Chainsaw oil
32 to 1 and it combusts fine at high and low rpms ,piston is oily ,can is dry .View attachment 14814 View attachment 14815 View attachment 14817
Did you shut the saw off right after use or let it idle? I remember the oil thread on AS experienced members said if you let your saw idle several minutes after use the plug will be wet and not give you a representative picture. I usually always let my saw idle several minutes after use to cool down. Plus I like hearing my Mastermind 660 idle. My Mastermind 372 sounds even better like my CR-80 when I was a kid.Chainsaw oil
Lmbo!! U aint right!!!No, no it's not, this is Randy View attachment 14831 after he came back from the doc a few weeks back.......
Damn...wasn't expecting that. Hernia surgery?No, no it's not, this is Randy View attachment 14831 after he came back from the doc a few weeks back.......
Is Saber or Dumonde your favorite so far?Chainsaw oil ,but may double as after shave ,looks like the old aqua velva View attachment 14829 View attachment 14830
Are we measuring peckers?
Chainsaw oil
After all this stress debating oil my blood pressure was only 100/63 today at my routine Dr. Appt. checkup. Heart rate 61. Slinging a maul keeps you in shape. And I'm not on blood pressure medicine....yet.Enough of the pecker contest!! Lol!! I made Pinnacle OPE member by comparing peckers today!!!![]()
Ive ran Saber a good bit. Nothin wrong with that oil. It burn in the upperend comparable to R2 imoImagine after all these pages of oil threads an oil blended for chain saws and other OPE by Amsoil is decided to be the best oil to run in OPE....oh the irony[emoji1]
