X 66 stang347 X
9:29 AM
Georgia
No name black bottle mix from gas station
jakethesnake
I Am The Snake
9:29 AM
Here & Now
Just received a quart of klotz benol. Never used any castor. Does it store ok or would you fellas use it through an ever day typa Saw? Only reason I dislike it is I hear castor tends to seperate. Pretty sure most of the coldest weather is behind now. But when farming picks up. Saws sit cept for a random tree needing cut off. I'm using low smoke husqvarna at the moment. It has stabilizers and like. Does the klotz or negative?
Adirondackstihl
9:29 AM
Upstate NY
Negative
Shake well after let sit.
Benol....meh....I wouldn't run it long term
PissRev
9:29 AM
Ga
Just an add in. I probably will never buy it again because it cost about the same as the oil did, but I had to try it and it really does smell good. I even put it in my mower and 4 wheeler. Exhaust smells just like raspberries.
