X 66 stang347 X
- 10:13 AM
- Sep 23, 2016
- Georgia
No name black bottle mix from gas station
NegativeJust received a quart of klotz benol. Never used any castor. Does it store ok or would you fellas use it through an ever day typa Saw? Only reason I dislike it is I hear castor tends to seperate. Pretty sure most of the coldest weather is behind now. But when farming picks up. Saws sit cept for a random tree needing cut off. I'm using low smoke husqvarna at the moment. It has stabilizers and like. Does the klotz or negative?
Freebie. 1 quart n done likely. Not all that picky on my oils. Thank yeNegative
Shake well after let sit.
Benol....meh....I wouldn't run it long term
Like i said, he be using it az a lab!Yikes. May not even be oil. Ugly.
Understan what imm sayn?o
