11:37 AM
(Anytime) you run a saw, I.e. Continue to run, knowing in your head (e.g. ear) that it is running lean, you are dancing with the devil....
That was the first of the belray h1r I used. Never dreamed the rpm would go up 1500 rpm almost and 2 turns out on the H to get back to 14k. Saw ran perfect on klotz and would tune down to a better 13.5k. I had made maybe 3 cuts with it when that happened cutting cookies. If I had tached it or just held it wot out of wood longer I would have heard it.
Terry Hennessy
10:37 AM
Memphis, TN
jake wells
no longer here
10:37 AM
ky
Keith knows I was joking. I only use 800 off-road in all my saws, ported and stock, with zero issues. The Logger that uses Safe Guard oil says he's found out that it's the QUANTITY of oil not the TYPE of oil that counts. He's also used Lucas synthetic and husky synthetic oil but didn't notice any improvement in the life (longevity) of his saws. I doubt if anyone reading this thread has ever experienced an engine failure using a 32:1 mix with ANY brand of oil. If so, I'd like to hear about it.
i have experienced bearing failure in low speed 2 strokes and they were run at 32:1. but it isn't the result of oil if is from over speed.
Redbull661
661 hoarder (BlueBallz)
10:37 AM
MN
Im willing to bet that even the amount of engine failures running 50:1 is VERY low in normal conditions. And most of those failures being from bad fuel.
I agree. But the key is "normal" conditions. IMO 50:1 doesn't leave enough fudge factor for anything outside normal conditions.
So many benefits to running 40:1. Even if your paying say $15 for a quart of 2t oil. It only costs .35 cents more per gallon mixed, to run 40:1. Heck run 45:1 (at least you get 10% more oil than 50:1) cost ya an extra .17 cents per gallon.
Me personally, yeah I'll pay an extra .25-.35 cents whatever for a little added insurance, a faster saw, cooler running saw.
Keith Gandy
Maxima K2 40:1 87 Pump Gas
10:37 AM
Provencal, Louisiana
- the only reason I am testing, is to find the best PERFORMER...racing...if there even is one.
Im liking the sound of 25to1 or 20to1
Ron660
10:37 AM
NW Louisiana
One Logger I know said when he increased his mix ratio, Safe Guard 2-cycle..cheap stuff w/87 octane, from 50:1 to 32:1 it doubled the life of his 372's (av. 1.5 years to about 4 yrs.). That's coming from a Logger that his crew uses 372's on a daily basis in all kinds of conditions.
Keith Gandy
10:37 AM
I would think most of the folks that use their equipment professionally as in logging just want it to run and cheap as possible and never see it internally and could care less. Its a tool and needs to work is all that matters probably
Ron660
10:37 AM
NW Louisiana
That Logger told me another Logger told him about adding more oil to his mix to make his saws last longer. The other Logger mixes 25:1. That proved to me more oil helps. Plus they use their saws more in one to two weeks than we use in a year probably.
Ron660
10:37 AM
NW Louisiana
I wonder if using more oil, like 8 ozs. (16:1), would increase the life of your saw even more?
Ron660
10:37 AM
NW Louisiana
If you have time compare 32:1 to 20:1 with some timed cuts to see if the extra oil is hurting performance.
