KenJax Tree
¯\_(ツ)_/¯
- 11:19 AM
- Dec 31, 2015
- Over there
Anything being discussed here that wasn't discussed 100x in the most epic oil thread in AS history ?[emoji1]
ms200t is ghey!Anything being discussed here that wasn't discussed 100x in the most epic oil thread in AS history ?[emoji1]
Yes to me it is. Thoso 2 sets of pics I posted show the same saw run the same way with the same fuel at the same ratio and what the oil alone did in the saw. Different oils act differently in sawsAnything being discussed here that wasn't discussed 100x in the most epic oil thread in AS history ?[emoji1]
Jake this paticular saw is starto gutted so that may make a difference?strange that my autotune saws run a little lean and the mtronic saws run a little rich.
I will but may take me some time as work has me tiedSo what if the solvents in 2r did account for something? What if 32:1 2r would really be like running 40:1 ?
Keith would you be willing to run this simple test?
Run 2r the same way at 25:1 and let's see the pattern on the piston top
then
Run hp2 at 40:1 and let's see the pattern on the piston top.
Do the same everything you did with the earlier 32:1 test.
I just got cold, no snowy ...... HEY, we're talkingCold and snowy is nothing to talk about
not sure?Jake this paticular saw is starto gutted so that may make a difference?
I have ran 2r at 20:1 and the pistons look very clean. In fact I think over all a motor will be cleaner internally when running more oil.I will but may take me some time as work has me tied
Not to ruin your day Redbull, but HP2 does contain the dreadful solvent..So what if the solvents in 2r did account for something? What if 32:1 2r would really be like running 40:1 ?
then
I think you worry to much about inconsequential stuff.. just go cut wood!oh I know. It's not that I don't like them. It's just I think they should be accounted for as part of figuring out how much oil to use.
This saw has had the strato system stripped from the back of carb to the intake port window and 6° of intake duration added. It flows alota fuel!!not sure?
very thirsty huh i know a guy who gutted the stratos on a 211 and made it a good saw.This saw has had the strato system stripped from the back of carb to the intake port window and 6° of intake duration added. It flows alota fuel!!
