stihl saws
You can always justify another saw.
- 11:53 PM
- Jan 18, 2016
- Virginia
Says the "Tony Montana" of saw porting.I'm moving to The Keys.........buying a boat.....
My fs460c was alil boggy on the trigger and I reset it and presto! Instant throttle! That didnt help when I was cutting with it behind the house in the woods and about 20 yellowjackets tagged me this morning !! Lol!! I was running and stripping at the same time!!!! They were stuck to me head to toe
I hear u man. This unit is mtronic though. Adjust itselfI hate those yellow jackets and they get more aggressive in the fall and come right after you .
Not a funny situation , been there too !!
The bog off idle is usually the low being a bit lean Keith .
Well..... That's going to increase shipping!I'm moving to The Keys.........buying a boat.....
What color is the Honda stuff?
I assume red?
Unfortunately (perhaps) the Honda GN2 is straw coloredIdk about that stuff. HP2 is bright blue
Smells yummy!I remember the other reason I didn't use 800 much. Burnt 3/4 of a gallon today and yesterday. Mulled today and the exhaust smell is strong.
YeahNot when it's in your face for 6-7 minutes at a time. It's going back on the shelf for assembly lube or to be dumped on a hay baler chain.
That's weirdDon't burn unless the saw is milling. Piston top is solid black goo.
Try the saber yet ?That's weird
The 3 044's I ran and tore apart were spotless with it after 4-5 gallons. I don't run pump gas though....maybe that's the difference?
I just bought another quart a few weeks ago. Now you got me pondering.
Maybe I'll replace the 800 with HP2?
YepTry the saber yet ?
You have to load it hard to burn dry at 40 to 1 ,limbing it will looks like a wood stove pipe though .Yep
Thought it was kinda sooty
Still haven't tried the MX2T yet though
I have been known to tune rich off my ear.Tune them lean enough to burn and it makes a mess almost like some of the other ester oils. If it's real rich it will clean the piston. I've run it with VP, Trufuel, and pump gas of all kinds. Its a bad choice for saws unless you maybe try it at their recommended ratio of 60:1.
I was mixing it @ 40:1.You have to load it hard to burn dry at 40 to 1 ,limbing it will looks like a wood stove pipe though .
The saber runs ok ,does stink if work under it like post hole auger use,i like that it has blue dye to see it's mixed and has stabilizers ,the mobil has almost no smell ,runs good ,but no dye in it or fuel stabilizers that i am aware of ,couple of my carbs gummed up leaving the fuel in over the winter last year with mobil .If i have to drill more fence posts ,i am going to mix up some mobil next time ,you can literally breathe it in and it does not bother me too bad compared to most oils .I was mixing it @ 40:1.
I would run it again.
I just like the smell and protection I've been seeing with the 800.
You still running the Saber?
Thoughts on the MX2T?
