- 11:36 AM
- Feb 4, 2017
- Winona County, MN
I see what you did there - and you’re not wrong!As the power increases, the heat increases![]()
Damn…that’s nasty. I think it needs some antibiotics.I received a free H136 with a Chinese engine and unknown oil in the fuel
Yes, switch to AmsoilI use Lucas gun oil. Is it gonna blow up?
Citgo and Mystic both market really good yet cheap Air cooled two cycle oils also.View attachment 443333View attachment 443334
This is a good oil if you could get it at a good price. I burned through 5 quarts of this whenever I got it for $2 each and I can buy it full price here for about $10 a quart. Clean burning, hardly any smell or smoke.
Last I knew Citgo made all of Mercury/Quicksilver's lubricants.Citgo and Mystic both market really good yet cheap Air cooled two cycle oils also.
I’ve used it. It used to have the FD logo on backView attachment 443333View attachment 443334
My old timer neighbor swears by Penzoil tcw rated @1oz per gallon in all his 4T's kept 'em healthy.is there a 2-stroke oil that would do a really good job of cleaning carbon from vavles and pistons in a 4-stroke engine? at any mix ratio maybe 100:1 or leaner?
You would probably have a better chance of cleaning it using Redline SI-1 then using a 2-stroke oil. Chevron Techron, Gumout Regane or any other product using polyetheramines do a better job of cleaning out the combustion chamber.is there a 2-stroke oil that would do a really good job of cleaning carbon from vavles and pistons in a 4-stroke engine? at any mix ratio maybe 100:1 or leaner?
