- 2:43 PM
- Feb 5, 2016
- Here & Now
If you are gonna use it. At least go 32:1. I think it’ll be ok at that ratio but 40:1 failed me
I wouldn’t run it at 25:1, but he likes it and it’s working for him, so there’s that.If you are gonna use it. At least go 32:1. I think it’ll be ok at that ratio but 40:1 failed me
He enjoys the banter.Well, you are the one that let BWalker back for the umptheenth time, don’t blame us common folk…
I agree. It worked for me too. Until it didn’t. Incident wasn’t isolated either. It was everything I was running.I wouldn’t run it at 25:1, but he likes it and it’s working for him, so there’s that.
Tell you the truth I don’t remember every detail about that saw. It did have a larger carb on it though. It was finicky to tune. Just needed to be done weekly. (Annoying). What failed was my crank bearing It just wore out enough to allow too much travel Piston ended up hitting the top of the cylinder Internals were dry so I grabbed my perfect running 272 and pulled the muffler. Far too dry for my taste. I put 2 and 2 together and switched oils. (Went to cheap husqvarna “low smoke”). After the change everything was shiny inside after checking insides at a later date.Good evening Jake, thanks for the warning. I was able to find your pictures of the ported husq 346 back in 2016? Had you also mentioned that saw was hard to get enough fuel during tuning?
Yes I have no doubt that if something sat for a while, the lucas stuff would evaporate out. I had wiped a bolt on a rifle with lucas 2 cycle oil. Put rifle in the gun cabinet and it was dry couple months later. The oil evaporated away.
Stay tuned when I tear this cs 590 down, after a year of cutting. 32:1, 90 octane, 2 oz marine stabil per 5 gal jug. Though many of my other saws have run on all sort of other oils, the 590 has only ever run on lucas, since new.
In all the saws I've gone through about 25 gallons of this mix since last February. Lucas oil in the yamaha enticer 2, about 4 years of pulling slabs, firewood and a trail groomer (tractor trailer tire).
Thanks for doing the leg work joeDoesn't appear to have, just >60% hydrocarbon solvents.
He did. It didn't do well at extreme ratios.Tell you the truth I don’t remember every detail about that saw. It did have a larger carb on it though. It was finicky to tune. Just needed to be done weekly. (Annoying). What failed was my crank bearing It just wore out enough to allow too much travel Piston ended up hitting the top of the cylinder Internals were dry so I grabbed my perfect running 272 and pulled the muffler. Far too dry for my taste. I put 2 and 2 together and switched oils. (Went to cheap husqvarna “low smoke”). After the change everything was shiny inside after checking insides at a later date.
At 32:1 you might be ok but in my uneducated opinion it’s just not a very good oil.
I can run red armor at far less ratio and still look good inside. I don’t pull saws apart just to check as I don’t care that much but I do occasionally have an issue that has me pulling carburetor or muffler and haven’t seen anything since switching away from the lucas that caused me any concern.
Any of you fellas know if egg tested lucas ? How did it do? Poorly I’d imagine
Kinda figured as much. ThanksHe did. It didn't do well at extreme ratios.
good reference for this thread, not trying to argue, I use 40:1 dominator in all my 2-stroke stuff.
Sounds like my evaluation of it as wellIt did so poorly in fact it was deemed not worthy of further testing.
