Da dog man
- 6:56 PM
- Apr 6, 2024
- Indiana
Any word on motorex cross power 2T?
It's an excellent oil and is the oil that comes in every KTM, Husqvarna, and GasGas 2-stroke bikes.Any word on motorex cross power 2T?
It has been a minute since I have looked at a report on this topic. I will see if I can find it again. I want to say that that 50:1 was estimated to drop effective octane rating between 1 & 2 points depending on the oil used.what do you think the octane rating of 91 non ethanol gasoline is, after its mixed 40:1 with 2 stroke oil?
I asked Mr Google that question just exactly like you posed it here and this was the response from AI:what do you think the octane rating of 91 non ethanol gasoline is, after its mixed 40:1 with 2 stroke oil?
Yeah man who knows if this is actually correct but this is what Google Gemini AI came up with.huh interesting, I would have guessed it would have cut it down 10 or so points.
No.do you guys think enviromental factors come into play, like humidity, temperature, mixed with altitude air density. would that have an impact on oil performance in different regions-climates?
I've been running 40:1 dominator since I started reading this thread a few years ago, I can notice an increase in power over my old mix of husky oil at 50:1, but its got me wondering if maybe the fuels and climates favor that mixture for me here, and someone in a different region might need a completley different recipe.
I have never noticed any oil to be "sticky". Some pre mix oils are thicker some are thinner.Is that how ester do?? Dom leave a oil film that is not as greasy as Saber on the bottom end, Super M and K2 both do leave a film like 90 weight oil with a hair of tacky feeling. Man I should stop buying different oil and stick to one lol.
Those 4 oil I've tried are all good. Maybe just some different characteristic.
Almost forgot to mention the bean oil Maxima 927, that stuff is gummy! Not really mean for chainsaw I think.
What's it matter? Saws have such low compression ratios it's pointless to worry about octane.what do you think the octane rating of 91 non ethanol gasoline is, after its mixed 40:1 with 2 stroke oil?
I beg to differ...I used to think I could get away with efree 87 for my ported saws. I have had a couple that wouldn't shut off....I have only had it happen once since I switched over to 91 efree, and in that case, it was an issue of too much timing advance. Some saws even after machine work will never get enough compression to have issues, but some can up there in a hurry.What's it matter? Saws have such low compression ratios it's pointless to worry about octane.
Also consider that the fuel air mixture inside the combustion chamber doesn't have a significant amount of oil in it. The only time it does is prior to the engine coming up to temp, which is one reason two strokes smoke more at startup.
You are describing pre ignition, which octane doesn't prevent. As you mentioned your timing was too far advanced.I beg to differ...I used to think I could get away with efree 87 for my ported saws. I have had a couple that wouldn't shut off....I have only had it happen once since I switched over to 91 efree, and in that case, it was an issue of too much timing advance. Some saws even after machine work will never get enough compression to have issues, but some can up there in a hurry.
Tree monkey is a smart guy and is right.Lots of guys including tree monkey say detonation in a saw is really hard to do even at over 200 lbs compression. But i haven’t tested it so i wouldn’t know from experience, was a few guys building pretty high compression saws like 220 and still running 87 but I don’t know if they had issues.
I put an 028 super piston in a Husqvarna 55 once, it had 250 lbs compression, no detonation. I could have been running 90 octane, can't remember. It ran really good but was a nondecomp cylinder and too hard on starters so I took it back out.Lots of guys including tree monkey say detonation in a saw is really hard to do even at over 200 lbs compression. But i haven’t tested it so i wouldn’t know from experience, was a few guys building pretty high compression saws like 220 and still running 87 but I don’t know if they had issues.
I need to pull it apart and dish the piston.Hate a saw that needs to be tuned every time you run it. Had a couple. They sit on shelves now
