Keith Gandy
Maxima K2 40:1 87 Pump Gas
10:58 AM
Provencal, Louisiana
That's a lot of oil. I'm not surprised with your findings though.
On the new Autotune saws though, they can't tune themselves with that much oil. It puts them outside their calibration parameters.
Thats hp2 @ 32to1 in a 241 thats been strato gutted and was ran wot the last 5 tanks cutting cookies and shut down at wot. Alota oil left
Keith Gandy
10:58 AM
Ever use that ring-free anymore?
No I dont worry about alil carbon buildup because I know its normal and is a sign of complete combustion. The yamaha ring free and stihl decarbonizer was intended for powervalves and valves in 4 stroke motors but it wont hurt to use alil in a chainsaw or other power equipment and will help if ones focus is a clean piston
W
Wendell
Guest
Redbull660 did a very in depth oil test on the MS661 that really opened my eyes. Even at 32:1 with Belray H1R the saws lost about 30% in cut speed over 50:1.
Interesting; some of the tests I read where based on air cooled motorcycles & the thicker they ran them showed more HP; they thought it was sealing the rings better. Do you know anyone with a chainsaw dyno? I was thinking about building one using a small single stage hydraulic pump ran with the proper belt pulley gearing to compensate for the saws rpms & the much slower rpms required on the pump side; if you've got pressure & flow a simple formula will give you HP. Looks like the most expensive thing will be a reliable high pressure gpm meter
junkman
Crush it
8:58 AM
pacific northwest
My findings ,thougj could be wrong. ,what works in a 50 hp dirtbike may bog a 5-8 hp saw and lose power. I may be wrong though .i have no dyno
10:58 AM
It just so happens, there are a few guys brainstorming dyno builds here using the conversations as a thread.
It's not ring seal that slows down the A/T saws. It seems to have something to do with the oil inhibiting combustion.
11:58 AM
Belray was the worst. Motul 800 doesn't seem to slow them down as much but it makes a mess in a 550xp.
Keith Gandy
10:58 AM
Im buying that and its what Ben has said for awhile. Look at my piston and all the oil left and I ran the heck out of that little saw for about 5 tanks one cut after another at wot! Im trying r2 which I think will burn more complete than the thicker oils. K2 may still be a best bet or r2
Ron660
10:58 AM
NW Louisiana
R2 has a very similiar viscosity as chainsaw oils. R50 and 800 has two-times the viscosity. Mike, ever use R2?
11:58 AM
Do you think 87 octane will produce more engine heat than 93 helping with combustion of these high viscosity racing oils?
I think it will be close to the same heat. The VP burns very clean so I don't know what caused the build up so quick besides the oil.
