jake wells
no longer here
12:31 PM
ky
shindaiwa had it produced for there hybrid 2 cycles kind of like the 4 mix stihls but better.
skidooguy
Genuine smartass
11:31 AM
Wyoming
Our local farm and ranch store just became a dealer of shindawa so I'll give the red armor a try. They also seem to have bar oil on the shelf that's way cheaper than the coop and it's the same brand.
johnny5ny
1:31 PM
Saratoga Springs NY
I go straight Fomblin Oil. It's only about $500/liter, so sometimes I even use it as bar oil. I mean who wouldn't sling it all over the woods at ~ $34/oz????
smokey7
1:31 PM
Detroit
How long has ur plug been in ur saw with the amsoil? Can you snap a pic please
Keep in mind his plug will look different as he is tuned rich for milling. Likely will have carbon on the outer edge of plug near the threads. I still believe it's very good oil.
junkman
Crush it
10:31 AM
pacific northwest
I have the same plug that has been in there a while now ,i have it tuned about 13k a little rich ,but it still burns pretty clean
i need to get batterys for my scope camera still ,i will get piston top and plug images soon .
junkman
Crush it
10:31 AM
pacific northwest
Heated handle saws are made for colder climates ,would the main jet be leaner in the heated handle saw ?
1:31 PM
Some of the other ones did have different jets if I remember right
1:31 PM
@junkman and @Keith Gandy, have you tried Motul 800 yet? (Pretty sure Brian barfed at the red dye).
I think it sucks unless the saw is on a mill for hours at a time. Other than that it leaves a wet piston top from not burning. It will make some hard deposits after milling if it's ran hard enough to burn.
Keith Gandy
Maxima K2 40:1 87 Pump Gas
12:31 PM
Provencal, Louisiana
well if schaeffers can clean this thing up. I'll check again and see if there is still a difference. That said I got this saw from Dave in BC. It's 66F there right now and 78F here.
661 #3 had the slowest times of the day in all 4 logs. So I guess not.
Only makes sense in a 2 stroke that a cooler running saw isnt gonna make more power . A 2 stroke needs the proper load and temp. Range for the oil to combust. If it isnt combusting it will end up wet, washing the piston, and making less power IMO. Extra oil in the topend thats not combusting is like pouring water on the fire. Like Mdavlee said 800t wont combust, burn, or make full power unless its a load and temp that milling produces. Just my opinion
